- Apr 20, 2004
- JAX, Mississauna
^yep^
^yep^
OH Myata. Hehehe. Looking good man.
RGone...ster.
EDIT:
For sanity sake and knowledge, I would run that P95 Blend for 2 hours and see if all stays in line. It seems it could. At the end of two hours, you should be able to deem yourself pretty darn stable and tweaked pretty well.
END EDIT.
4.8 or 4.9 just won't make it eh! I think the jump to 4.8 would require just a bit more Vcore and that would be the absolute limit if not over by the way this is playing out.
Fugu, I have one of the lower voltage 8350's out of the group of us, meaning I can usually get to X mhz at slightly less Cpu V then some of the others, ie Johan, Caddi etc. Every chip is different but 1.41 is most likely as Gonester stated way too low. I need 1.46875 with much better cooling for 24/7 stable at 4.7.
Your original failure at 4.7Ghz required a boost of 0.03 to get stable. But that 1.44Vcore that I suggested is at the bottom of what many actually need/require. So 4.8Ghz? You are own your on there man. I showed you the prinicple and some numbers based on the many 100's of these things I have tweaked by the ether and many many hours with my own cpu.
It took me about 2.5 weeks to get my now air-cooled FX-8350 to run 4.7Ghz stable. Hours of very minor adjustments. Got it but you think I would try it by 'text'? Heck no.
RGone...ster.
Crazy, there is a group of us here that have overclocked the wee out of our chips. Most of us have pushed our chips into the mid 5's, though non of us will say our chips are stable at those clocks nor tell people we have our chips at those clock speeds. I can browse the net at 5.2, hell I have even ran a game at those clocks but it isn't anywhere near stable, nor would I advertise my voltage to run it there and tell someone that this is where I'm at for a stable OC.I'm at 1.368 at 4.4GHz. I don't imagine I'm going to have huge voltage jumps bumping to higher freq's. My buddy has almost the same build as me and he's at 1.4 at 4.4Ghz. I have no idea why he requires that much voltage.
Ask everyone of us what we deem stable, every one of us will say 2 hours prime blend at a minimum. At your 4.4 speed you have not even come close to running 2 hours of Prime, mostly due to your heat issues. Telling someone that you're at 4.4 @ 1.368 doesn't help anyone because in most cases it isn't stable. Pass two hours of prime then lets see what your 4.4 voltage is.
The temps are looking good. Hey you're a Canuck just open the window a bit and cool the room. Ha ha ha
There's a few of us here that do that kinda stuff. But just closing the door and cracking the window can make a reall difference. I see your board is a bit los on power so you wouldn't want to go too crazy but it can give some relief to hot computer parts.
This is what I do in the winter.
http://www.overclockers.com/forums/showpost.php?p=7589445&postcount=1096
Johan instead of the //////// you can try the left and center BB codes"johan22.5", what in the heck are all them //////////// in your siggie? U get sum other type rigging?
