- Apr 20, 2004
- JAX, Mississauna
Okay i see. No system are the same.
It ran prime95 all night and its 9 hours now and still no error at 200*20 1.275 volt. Core 38 and CPU 52 so i let et run all day and hope its okay, then i take it step by step.. Thx.
If that thing is running P95 Blend mode for hours at 1.275V; you are one lucky person. I wonder if the LLC is set to extreme and the actual loaded voltage to the cpu is really higher? Because CPUz > CPU Tab shows 1.414 Volts and so does HWMonitor (free) but that other monitor program you have which looks like Open Hardward Monitor is only showing about 1.236 volts. Something is off somewhere if both monitors and CPUz/CPU Tab are showing LOADED statistics.
RGone...
