- May 3, 2013
- Ontario, Canada
I'm using a HAF XB for my 8350 build with decent success. With a Hyper 212+ mounted, my options for a top mounted fan were limited; I had to go with the thinnest fan I could find and even then had to mod the fan slightly to allow the top cover to slide on and off without contacting the 212+.
I run 2X140mm front fans as intake, top mounted 200mm as intake, rear 120mm as exhaust and a push/pull setup on the Hyper 212+. This allows me to run the 8350 at 4.6 GHZ without exceeding 60 Celsius in Prime. At 4.7 the temps start to skyrocket so 4.6 is the max speed on air with this particular setup. I doubt any other setup would give much better success on air.
In a nutshell, the HAF XB does a good job in thermal management. The only downside I've found with this case is the lack of 3.5" drive bays; if you have more than 2 3.5" drives your SOL on mounting them. Of course it does present a good excuse to upgrade to a bigger, faster SSD instead as there is plenty of room for 2.5" drives.
