- Aug 26, 2012
- NCR, Philippines
- Thread Starter
- #21
hmm.. but I'm thinking my A50 isn't just seated properly(maybe I just need to re-apply thermal paste properly). Shop put parts up together for me or is the A50 just really crappy?
Well.. problem is I couldn't find any shop (locally) with 212 on stock always out of stock thats why I got forced to get this A50. Also I got a very different ambient temp than you.. I guess.. around 28-34 degrees. Well if I were to buy a new cooler I'd just go for an H80 then or Noctua NH-D14 if it'll fit my case.(but I guess it'll be the H80.....)Sheesh, just a regular old CoolerMaster 212Plus had me below 55 degrees for a 4.1Ghz overclock on the 1090T. If a budget is needed, or a very quick fix, pick one up for like 20 bucks.
This includes 3 fans stock .....
■1 front mounted Fractal Design 140mm fan @ 1000rpm included
■1 rear mounted Fractal Design 120mm fan @ 1200rpm included
■1 top mounted Fractal Design 140mm fan @ 1000rpm included
■Additional 4 fan slots available for optional fans; one 120mm in front, one 120mm in bottom,one 120/140mm in top and one 120/140mm in side panel
Lol, I lowered my voltages then got a BSOD while running prime95 then now my computer wont detect my hard drive. What do I do?
I had a problem with my side fan being blocked by the GPU entirely so I moved my GPU down to the PCI-e 8x slot so the fan could blow over the the card and feed the CPU fan.
Might try something similar.
