OK, first please explain "Prime95 suddenly not working". Do you mean it won't load, wont run, or you keep getting dropped workers?
Compliments of Johan45.
The voltage fluctuation is probably a result of the LLC. It's probably on Auto if you haven't adjusted it. So it is normal and not necessarily bad. You can keep your main voltage lower while having the boost when needed. As long s it's holding steady at the 1.49 when under load should be fine.
hmmmm it may be impossible for me to do that. My backplate covers everything.
Update:
past 3hrs of prime95 now. Awaiting on a BSOD to come.
Why are you running 800 @ 933 timings? What is the Ram voltage?
Those sticks should be able to run 8-8-8-24-32 @ 1.5v 800 Mhz.
The SPD latency which would be the 1333 divider is 9-9-9-24 @ 1.5v
If you want to run 933 like they should be, keep your timing set and manually set the voltage. I'd give it a bump considering most of the Phenom II mem controllers don't play as nice at 933 as the FX IMC's do. Should be ok to 1.65v, But I would think that just a small bump might get you there.
On the Cpu end, assuming the Ram is in order and should be ok at 9-10-9-27 800mhz, although loose, should be stable IMO. But anyhow the Cpu voltage looks a little low at 4ghz. Meaninig 1.5+ volts at 4ghz is pretty much common place. Some take more than others. Just keep on testing.
If this is your Temp at 4ghz, forget it. It's too hot and that's your blue screen problem. If you reach the temp restriction set in bios, the board will just shut off from heat. I'd lower that to 65c being you don't really want to get any hotter than that.
@ Meatball - Congrats! You have reached your goal of 4.0Ghz. now it's just a matter of getting those fan splitters and cooling your VRM and sockets. Good work
@ ShrimpBrime - I maybe wrong but I thought I read that Phenom II's will only support up to 1600 ram. (?)
As far as I know it only officially supports 1333. That being said the 965 BE that I have will run over 1600 and I think the IMC on the Thubans was improved. I have no personal experience with them so not sure what it's capable of. But there's no real harm in trying. Think of it as free performance if it works. Just find your DRam timing in the BIOS and adjust the first 4 settings to the #'s in the SPD tab under 933. Add a touch of voltage to the ram and it may surprise you.
From what I see those are already the setting in the BIOS on Auto I assume if you've never set them. Just verify those are the numbers and lock them in so the board doesn't change them on you. 9=10=9=27=37
