- Aug 26, 2012
- NCR, Philippines
- Thread Starter
- #61
Arctic cooling products here easily get out of stock, most available ones are the Prolimatech PK-1 and Tuniq TX-4.
Man, bassnut, that's pretty innovative. And it doesn't even look very ghetto!
OK, just incase it hasn't been mentioned...It looks like your CPU multi is variable from (4-18.5). If I'm not mistaken this is an indicator that you have turbo mode active. If so you're going to want to turn that off. It can cause instability while OCing. If it's off I would bump multi to 19 and stress.
2200 on NB is right about where she wants to be. Each system varies so if you do get a fail try bumping NB up or down. If you still get fail then give vCore another bump.
I'm curious to see the improvement the H80 with good TIM is going to do. (keeping in mind it probably wont help the socket temp)
Maybe CnQ was enabled last time you cleared CMos? Grabbing at straws.
