- Dec 19, 2012
Are you using all the up to date drivers from the motherboard site?
Silicon lottery doen't specify anything but V_Core from that link and the OP has a 7/10 chance of getting a worse CPU.
What I do know is every voltage in the CPU runs from that rail so depending on motherboard and their auto function the VCCIN needs to go up as voltage requirements go up and is very CPU dependant. What you'll see is raising V_Core can cause a no boot scenario or low performance in benchmarks even though it'll still pass stress testing these are my observations from overclocking a 7820X/7900X and 5960X.
If overclocking stability is attainable with increasing the Vcore and the stock 1.8V VCCIN then that is all that needs to be done. The real problem comes with what the processor will do with overclocking limits. As of 12/01/17, the top 31% of tested 7980XEs were able to hit 4.4GHz or greater. https://siliconlottery.com/collections/all/products/7980xe44g
