After doing this test, I guess, if not my Motherboard, then it is my CPU really having a weak IMC,
Tested all 4 sticks one by one, turn on XMP, can't boot up my PC and the error code shown on the MB is code 04, Test NVRam. (Same for all 4 sticks)
Can I say that all my hardwares are fine now? do you recommand me to run one last test by using SiSoftware Sandra Lite Platinum.SP4?
Stress test passed for this setting (All auto, except DRAM FREQ set to 3600, 1.4V, 16 18 18 38) so far, Memtest86 (DOS), Memtest, PRIME95 (BLEND, longest run time is 7 hours without error), AIDA64 RAM benchmark, 3DMark Fire Stirke Ultra, Extreme and standard, CINCBENCH, REAL BENCH, Intel Processor Diagnostic Tool 64bit.
Thanks
PS: By the way, good find, I learn something new from the artical. next time I will surely consult with you guys before making expensive purchases. But this is also the first time I encounter such issue, must be lucky in the past.
It's good that you did the stick testing you would never know until you tried, now you can be sure 99% the memory is not the problem with overclocking. You are just unlucky this time with the IMC, the ASUS X299 article I linked for you had the 4 sticks of DDR4-4133 running no problem with XMP. One thing I'm thinking could reduce your bench scores is the spectre meltdown vulnerability patch. Do you have the latest BIOS update ? If you do it should have the patch that can slow down performance.
