- Dec 25, 2004
- Thread Starter
- #21
Mine are the same model, PC-8500 1066MHz. I'm using 4x1GB with no problems. If you ever do get them to work, the voltage needs to be set at 2.2v for them in the bios, otherwise the bios will most likely see them as being 800MHz (even says so somewhere in specs).
Also, check your bios, see what version you are running.
Ahh nailed this one
It's more likely that just one or two of the sticks are bad though if jkeyser14 is running ballistix in his board. Hopefully this is the case and you can just RMA the bad stick(s).
Well, I think I've identifed at least 2 sticks that are giving me problems. I'm not sure what is happening, because all 4 seemed to work on the DFI 680i board I had.
However, I have two that will boot up in a computer here at work and two that won't boot in at least 4 different computers I've tried. So I'll take the two that are working back home and try them one at a time. If they both work I'll RMA the two that aren't. I'm pretty sure I've had them less than a year.
Thanks for the suggestions.
I'm currently running the 0601 bios, which I believe has some extra DRAM compatibility upgrades in it. And I've got plenty of fans and places to mount them for active cooling on the RAM.
