what do you use for cooling and which case?
also, have you always run your ram beyond spec? is it safe? i'm thinking about going a bit over 1.35v since my fan is sucking tons of air right over all 4 sticks.
ah ok. i guess i meant past 1.35v. if you've been at it awhile i guess it must be safe enough but the internet seems divided. i'll give it a shot but probably stay under 1.4v.
btw it's very worth the money to get a better cooler if your temps are that high. i'm very happy with the ouranos. it fits perfectly without bumping my side door fan and has enough space for a 25mm thick fan. cools pretty well. recommended.
do you think the 1.5v sticks are made to be more physically resilient?
meh i tried to oc my ram a bit but they don't seem to be the greatest. mobo shows red numbers when you type in 1.4 or above so i gave it a shot at 1.395v to see the best i could get. it seemed to be stable at 3200mhz cas15 and i guess 200 free mhz is nice but doesn't seem worth it for the extra volts. 3200mhz cas14 was a no boot and 3000mhz cas14 crashed realbench pretty quick as did 3300mhz cas 15 and 3400mhz cas 15 was a definite no go. ram temps were at 41-42c so maybe more volts are ok but asrock seems to think it's dangerous. i read that 4 sticks won't normally do as well and my ram is a couple years old so probably doesn't have the good chips like the newer samsungs. i need to upgrade after prices go down i think.
