Alaric
- Dec 4, 2011
- Satan's Colon, US
Yeah, one RX 580 or, better yet, a good deal on a used GTX 1070. I got one for cheap from an OCF member, and one sold in our Classifieds for $235 fairly recently.
Trick a nice HD7970 would be a perfect pair for that cpu. Better yet, a pair of them in crossfire. If you want, I know a guy. HMU
Oh man that would be so amazing. I just don't know if I will be able to afford it or anything any more (I am getting old and things are breaking down.) I go to see my doctor tomorrow Hope it is good news.
unless its one hundred for the pair I doubt I can get it now might have to wait till things get better.
I have to say this for the System it rocks. And it would be amazing fun to crossfire it just to max it out. I have the biggest CPU the MB can take (before melt down) the fastest DDR3 RipJaws Ram the MB can take and just to make it the best it can be it would be nice to Crossfire/SLI.
I know it's not going to win any speed records or blast anything new out of the way, It is just a nice gamer at a sweet price. (so far)
Sad thing is I just found out I have skin cancer
Vdroop.Looks like there is a massive amount of vdrope and my 3.3 volt rail is going out.
That is vdroop...You should be able to mitigate those effects by using Load Line Calibration (LLC) a function that should be in the BIOS somewhere.Any one know how the vcore is dropping off the 1.5 volts listed in bios? It would seem If I can actually have a steady 1.5 volts I could get that 4.5GHz on this Air cooler the Cooler master V8 GTS is a monster!
trickson what is the LLC set at? You can try changing it and see if it will help. That said, if it cannot be mitigated with the LLC, I imagine the Vrm section is struggling with Fx 83xx on board.
I looked around for the LLC and I could only find one other CPU voltage adjustment in the BIOS and that is the CPU-NB voltage. I am going to give a bump to the CPU voltage just a tad see if that helps. From the looks of my temps and the massive V8 cooler I should be fine for a test at 1.55 vcore. see if I can get 4.5Ghz!
If it were me, I'd get a hold of the V droop first. You may be able to overclock it higher, without additional voltage and/or lower the voltage. That is "if" you can get the voltage more steady.
I went through (I think) the manual for his motherboard, and it wasn't at all helpful. Unless it's in the pop up menu under Overclocking>CPU voltage (pop up menu) I didn't see anything that might lead to LLC. The manual is here https://us.msi.com/Motherboard/support/970AG45.html#down-manual if someone else wants to have a go.
