oppenheimer
- Nov 24, 2016
I made a mistake and bent up the faceplate for my RX480 and need to purchase a new one.
I have not contacted Saphire to ask about a purchase yet as I did this last night and I am hoping there may be someone who has needed to do this in the past and can tell me the best way to get one. Is there any type of water-cooling option which would do away with the faceplate handling retention?
Side complaint: Can they make it any more difficult to release the catch for the PCIE video cards on motherboards? Jumpin hotcakes man, this is an Asus ROG Extreme Assembly and trying to get under the card to kick down the latch is completely unreasonable. The card manufacturer should make a release on the card or Asus should make some form of extension for the latch. WHY make it that difficult?
I am going to pull my mobo now and check on the standoff situation. I think they are built in the case because I recall feeling standoffs somewhere around 1/4" but I think they were painted black like the interior of the case.
This is a brand new build and a few days into burn in, no overlcoking yet, strictly burn in, I came in one day to a code which per the mobo manual is reserved and there is no description. All the internet searches point towards every component from the PSU, mobo, etc but I did find my 480 was not seated all the way and hence I removed the faceplate and bent the crap out of it rather than walking away for a while. I left it alone today to get myself in check.
The case is a RioToro CR1280.
https://www.riotoro.com/products/cr1280-prism-rgb-full-tower-case/
I would be happy to go into more details regarding the actual problem I am troubleshooting, but mainly at this time I simply need to purchase a new faceplate. I bent mine up so the card would seat properly. I hope I find an issue with the standoffs, well, I kinda hope I do to correct the issue with the faceplate not fitting unless I bent it, but then I have to worry if the bequiet! Dark Rock Pro 3 will still fit. Per the quoted dimensions on the case it will, but man is it tight. It also leaves a very small, small as in you can see light but that is it gap between the heatsink and top of the G.Skill TridentZ RAM. I can only use two sticks as there is no way I am getting a stick in the first slot and I bought 4 sticks of expensive RAM because the quoted dimensions of both stated they would fit, but they don't. I can live with 16GB for now as I plan to water cool this CPU in the next few months and can sell on the bequiet! DRP3. It is a fantastic cooler imo.
While this is a new account I used to be a regular contributing member here about 10 years or more ago. My email changed on my old account so I am unable to get an email reset if the account still exists, so I made a new one. I look forward to becoming involved again with this new build and moving forward as this hobby is something which will never let me go. I would like to get into benching and modding again as that was always a true motivator. I never made it to the sub zero level, but I played around with peltiers, custom CNC water blocks, etc, this was before these things were commercially available.
Thank You for your time
