alright got it done! just curious what that does so I can learn.
Anything else I can do for an improvement? I am pretty happy with my overclock thus far. Thanks!
to screen shot the bios, plug a flashdrive into a usb port and press the f12 key.
use paint/save as/ png or jpeg to compress it to be able to upload them to the forum.
- - - Updated - - -
to know if we need to keep pushing the clock, what is the reason for the overclocking?
Well with timings how I understand it, the amount of time the each individual part of the ram holds and acts on the instruction it receives, until it passes it on to the next bank on the memory module. The lower the timing ie "tighter" the less time it takes and or has for it to act on the instruction and then pass it on to the next module. If set too tight it can cause instability. This is a good read on memory additionally this is a good guide for tuning the Fx chips. View attachment AMD_FX_Performance_Tuning_Guide.pdf
I ended up putting this back at auto. My comp was randomly having a hard time loading and updating webpages. Not sure if its a coincidence or what but since its been back on auto haven't had a single problem. Not sure if this would cause it or not?
Well the blend test also tests the ram and IMC which is necessary for stability. The CPU itself can be stable but if the rest isn't you can still get blue screens and lock-ups.
dang and it just failed set at auto running the blend. I dont see a CPU Nb Vid when I enter the bios. only CPU/NB frequency which is auto which looks like 2200.
that cpu/nb voltage should be fine for up to 2400-2600, but you might try up to 1.3.
remember, the cpu/nb is on the cpu, adding voltage and speed will add heat also.
have you added .05 volt to the ram voltage, example, your ram is 1.5 volt, you make it 1.55 volts.
Just an FYI and every setup is different even if they have the same components but my 8350 needs 1.3 Cpu Nb V to run my sticks at 1866 with the Nb Freq at 2200 Mhz. At 2600 Mhz I need 1.3875 Cpu Nb V.
