ok then, I would ask 2 things. HWMonitor on the temperatures that I have to keep an eye on are 2 right? TMPIN0 or TMPIN1? and temperatures core # 0, # 1 core, etc. ... must not exceed 62 ° C?
Keep TMPIN0 below 70 and all the cores below 62c.
So now the septum x18 multiplier with default vcore and launch "prime for 2 hours and do a screen about halfway through the test?
I will take a bit of time available, so I assume that we speak tomorrow evening
Yes and you should still be able to surf while running prime , if it crashes you're not stable
I used IBT because they could do the same thing as the prime, but using less time and was more comfortable
Sorry if I press this thing, but the voltage and timings of the ram (now I'm on auto) do not have to touch it?
Your Ram frequency and voltage should be set manually use the spd settings from CPU-z as a guide.
Thank you all
P.S. of prime95 I download the regular version or the one for 64bit?
I use a S.O. 64bit
Yes 64 bit
