tex4 said:nunez1980 Whats the green colored hoses?
tgp said:
yeh, looks like nb.
nunez....any tips or warnings at direct die now that youve got one down? like time saving techniques or things to watch out for that will save you time?
thx.
laters.
t
Big_Baller said:Where do we read? I know this is probubly the next thing I will do, when I have the money. Where did you learn about all this? Online? Classes? Job? It would be great if you could point me (us) to some online information.
tgp said:what! you allready made a dual evap setup!?
if so those are NICE temps for a dual setup. where are your cap tubes?
i would think at least 1/3. maybe even 1/2. no more than that though.
bowman1964@phase change.com made a 5 evap one. so if you could find the size of his compressor it should do your dual evap nicely.
Warlord2 said:hey looking good, glad you got it up and working well. Looking at your results I wish I could work on my cascade some more but Im going to college right now Just wanted to ask if you know what btu the 1/4hp compressor is and what vacuum you are getting on the cpu return line.
tgp said:so your using a 1/2hp compressor for your dual evap setup?
Warlord2 said:I would stick with the 1/3hp-1/4hp compressors, the 1/2hps are just too damn noisy. They are almost worse then those delta fans. My cascade setup is basically done, it just needs to be calibrated and I think there might be a small leak in it somewhere. I need to get ahold of some co2 to really take advantage of the cascade though, that its going to be hard to get. What kind of overclock did you get with the barton and the gfx card?
tgp said:
dude those are wicked temps for being a dual evap, especially your first try. would have thought you may, and thats a definate may, hit -15c on each one.
these temps are Celcius right?
