- Oct 16, 2002
- Thread Starter
- #61
Warlord2 said:wow thats still a really sweat overclock on the radeon, what are you benching with 3dmark3 may I ask?
I haven't tested 3dmark3
tgp said:what were you getting for one evap on the same compressor? what ive seen a dual evap almost cuts the single evap temp in half.
are you having any problems with your flex hoses getting brittle?
where do you get your temp meters from? those are nice. never seen a small non-scientific one go that low!
sweet dude, sweet.
TLKfatman said:to get better resalts from that set up u could take the liquid line and rap it around the suction line to supper cool it this would further cool the high pressure liquid after the condenser coil and heat the suction a little. Since your are in a vac u wont have this problem but it would also help to make sure there is no liquid coming to your compressor
tgp said:very nice man!
how did you make your block? hacksaw/drill? what pattern did you use on the inside? and wheres your cap tube outlet on the block?
what were your final temps on the dual evap setup?
nice work!
laters.
t
tgp said:hey man what happend to your grey drier's you had on there before? why did you go back with the copper bulb type????
can we get more pictures of the inside of that case? i still cant believe you fit that in there...
d00d O_O you fulfilled the common man's dream of making your own prommy!!! (phase changer self-contained astheticly in your tower) wowie-zowie-kapowie...and i was just about to give up... I keep teetering to the thought that "this is stupid excessive overkill" because I couldnt fit it inside my unit and it woulda taken an ugly outside box....but seing that someone actually did it....i'm goin for it man! thanx for liftin my spirits ^_^ heh!
Is that copper welds I see in the GPU block. Looks good
