Hi papadan, Good stuff - sounds like you may have a bit more headroom than me if you are 4.4ghz and such a low vcore.
The way I did it was probably wrong as I am pretty new to this! I left vcore on auto at first and watched where it peaked during the p95 test before failing and wrote it down. Then I went back and input that voltage manually into the bios and tried again. Here are my vcores so far:
CPU VID: 1.325v (per Coretemp)
vcore at straight 4ghz, no turbo, no cnc, all green stuff disabled not p95 tested: 1.308v
min vcore to get fully p95 stable at 4.5ghz; 1.368v (4.6% increase from last, 4.6% cumulative)
vcore to get stable P95 (small fft only) at 4.6ghz: 1.375v (0.5% increase from last, 5.1% cumulative)
min vcore to get fully stable P95 Blend 2 hours at 4.6ghz: 1.4125v (2.7% increase from last, 8% cumulative)
Hope that helps you out. Good luck.
