- Jan 12, 2012
You should post a screen shot of Hwmonitor under load with the new board maybe well see something that sticks out?Thanks Johan45, tried 803 and same thing - sticking with it though and upping the vcore...
I think the LLC on this board is more punchy than the Evo. eg for a given overclock speed, 'High LLC' on the Sabretooth is giving me the same idle vcore readings in CPUID as 'Ultra High' was giving me on the Evo.
I use your method & it is doing real good that way. My LLC is set on high also."twocents" let me describe CPU_LLC for you.
1. Set Cpu voltage in bios.
2. Make a choice of LLC setting so that the overshoot voltage is NOT too high when load comes on. So that under load the cpu is hopefully having the voltage you set for Vcore in bios menu.
3. So when you say the idle voltage seems a little heavy it is not LLC, make that a well working LLC's fault.
4. Now many of us have gone ahead and followed my setup offset Vcore method and on my CVH, I haul booty at 4.7Ghz and idle at 1600Mhz with 4.7Ghz voltage at 1.43V and Idling doing net surfing (no real load) at 0.986V. Doing so now on air instead of my heavy duty water and I was even able to drop from Ultra High CPU_LLC to only High. But it takes some tweaking with trial and error to get it spot on as I finally did do.
RGone...
Thanks RGone
Well I'm not at your level of expertise so I use Cool N Quiet. It works pretty good & you are right it does jump around some.Yes it takes a little tweaking to get "just" right which is what I need when the jump is from 1.6Ghz to 4.7Ghz and a "load". But once done...I just about forget about manual setting anymore. I just look for what is neeed to get offset correct. It is the use of offset that allows the voltage to drop so far when doing mostly nothing at low cpu speed. Cool n Quiet could do similar but it jumps all over the landscape to me and just not so pretty to watch.
RGone...
RGone...
