- Mar 3, 2012
- England, UK
- Thread Starter
- #21
Took all memory out????
I have recently overclocked my Fx-6100; Asus M5A78L-M LX Plus to 4.4Ghz and it is 2 hrs. stable in prime95 max temp of 50c on air. cpu vcore is 1.38ish multiplier is 21, bus speed is 210. I had initially set my cpu voltage to greater than it needed to be and stepped it back down until I had the lowest possible voltage for my current settings to still be stable.
My CPU-Z verificaton: http://valid.canardpc.com/show_oc.php?id=2280002 . Mind you this was before I was finished stepping down the voltage. I am not at home right now but I will try and check back later to see if I can help out more.
Edit: In the bios the cpu voltage shows as a 1.??? value and you increase and decrease using the plus and minus buttons on your keyboard. I think this is listed under jumperfree configuration, again I am not at home.
How did you change the VCORE??
My bios is set back to default and its still doing it. Wonder if its a graphics card problem
