- Jul 4, 2004
- Auckland, New Zealand
So I finally found out how to force a nvflash board id mismatch , i tried to unlock my 6200 to a 6600.. no go, the pipes are damaged.. had to blind flash back to a 6200.. bugger. anyway, while i was flashing i decided to unlock the temp probe and up the VCore to 1.4V.. and damn did it help!
(I have the NV43 A2 core[the 6600], btw)
I went from a max oc of 476/640, to 530/700 (added some sinks on the ram).. I was getting 64C load while running ut2k4's dm-irondeity (in the low fps room) on 1280*1024*32 everything up, 8xaa/16xaf for a couple of hours. Anyway, it seemed to be completely artefact free and stable on those settings.. even 3d marks ran stabily/no artefacts as well.. but the really weird thing is, when i went to turn down the eye candy (i dont exactly like 9-12fps in ut2k4, as you can imagine ), i booted up ut2k4 and the damn thing crashed.. reboot, started up 3dmark, the thing crashed.. im thinking wtf is going on here? so i up'd the eye candy to max again, and sure enough, both ut2k4 and 3dmark run flawlessly..
So naturally i thought it was the OC, so I put the gfx back at stock (400/500) and tried to run 3dmark.. i got artefacts all down the screen (in a \\ \\ \\ \\ kinda patern, if you can imagine that).. surely it cant be the added voltage thats causing these problems? I mean, with eye candy on, everything runs fine (albeit with very very low fps) what gives?
Also, just wondering what is the default VCore for a 6200? when i dumped my bios to mod it with nibitor, it couldnt find the VGPU info, so i had to use some bios editor to force 1.4V through it..
in a nutshell my questions are:
1) is 64C load an ok temp for a 6200 oc'd on load?
2) is artefacts/crashing without eye candy on, but running perfectly without, normal?
3) could it be the voltage thats causing these problems?
4) whats the stock VCore for a 6200?.. ties in with 3), as 1.4V might be too much.
Thanks in advance for the help guys
Careface*
Careface*
