- Aug 17, 2011
- Kailua-Kona, HI
Got to be careful with the compressors......
I just replaced the CPU for a friends daughters PC, her hubby used a compressor, I dont know what happened, maybe a static shock, but it ruined the CPU, which worked fine before that...
Not only that, you can actually blow off/ruin the components of the boards (musta been a bad solder joint or something for me) as this has happened to me. ruined some1's mobo this way; fyi 90psi is too much air pressure for cleaning.
Great thread, i do repair and the levels of dust/hair in the average case is amazing. Some1 asked why pc makers don't include fan filters... answer is so that your stuff overheats and dies, so you need to buy MOAR of their parts; job security essentially.
