- Thread Starter
- #41
Make sure your Windows 7 key can support multiple installations before counting on that.
Did you buy it in a brick & mortar store, or from an etailer?
Yes, I bought the home version from Best Buy. How can I check to see if the key supports multiple installations?
Again, after talking to some pro IT guys they laughed at me when I had told them I had everything except an SSD. Grab an SSD for this build no matter what. You WILL feel the difference. Pointless going with a mechanical for OS. Don't bother upgrading at all than. And yes stick with the 4GB GPU for future proofing if you're spending it all on this and won't be doing anything for the next 3-4+ years. If you ever need more juice, grab one used so I suggest grabbing a 4GB reference GPU since they are more common and easier to find.
That's still a pretty stiff price when compared to HDDs, but even so, I consider an SSD a must with any new build. Even just grabbing an $80 840 EVO (120gb) will make a world of difference.
So from all of this, I need to make sure I find an affordable SSD and a 4GB GPU card. What type of motherboard do I need to support these. Are all video cards now PCI Express 3.0 x16? Also, do intel chips still come with their own cooling fan or do I need to buy one?
