- Aug 15, 2017
- Yucca Valley, CA
- Thread Starter
- #21
Just completed over 7 hours of P95 while I slept. I dunno if that's normally 'good enough' to be considered stable? I want to work on overclocking the RAM next. That seems to be a tougher nut to crack then the CPU overclock. I've tried all sorts of timings and certain timings, even when losening them up just won't boot. When I put the timings tighter it will. For example I went for a 2800 OC on the RAM with 15-15-15-36 timings, didn't like that, but 14-16-16-31 it did, which is the same timings it runs at 2400. I crank the voltage up from 1.2 to 1.35 and my SOC is at 1.0v. I'm going to keep the SOC at 1.0 or higher even without the RAM OC as Johan mentioned. It did seem to keep things more stable just bumping it up to 1.0v.
Temps aren't an issue, I hit 67C on die, and 61C to 63C on CPU during that overnight run. Ambient in the house was pretty cool though, during the day I have seen Die temps as high as 73C, but still not a concern, as those loads were generated by IBT, which makes my CPU hotter than running P95.
EDIT: Always forget something... so the voltage is 1.412 Vcore, with LLC 1, gets me stable at 3.9Ghz for at least 7 hours of P95 anyways. Using offset voltage, but can't remember the precise number.
