I got a 4 aerocool sharks and it moves 82cfm is that good?
What exactly are you using to read the temps when unlocked? As once you unlock the cores the temps are all over the place if not at 0c, I never trust the temp reading on my 960t when it's locked to 4 cores as its just not right, I found the best way,was to use the socket temp -8c I know it's not perfect but I just don't trust the any other reading it gives out
Balanced intake and exhaust is best..
If your 5.25" is filtered but open as it looks liek it is, I would put one of the side intake fans in there, leave the rear as exhasut and make sure your HSF is blowing rearwards. (Which is looks like is possible with that setup.
If it not possible to do that with your Heatsink, have it blow down at the video card instead of blowing up at the top of the case.
If thats still not possible set bottom side panel to intake and top to exhaust. (Normally I recommend the opposite but normally side fans are farther forward on the panel)
Should be fine if they are running at full speed. Are they PWM fans, that is speed-controlled from the motherboard bios? If so, the PWM profile may need adjusting. It's usually found in a section named something like "PC Health".
I would use HWmonitor and go of the socket temp,as I would bet speedfan is giving inaccurate temps when unlocked, I have yet to see a programme that can accurately read a core temp when unlocked.I was using speed fan to get my temps when I unlocked
If you are idling higher with 6 than with 4 there's something wrong as mine idles exactly the same as with 6 but load temps are obviously different. Just something to think about
IMPG you got it
Luke , re lock you're chip run p95 for 15 mins check you're core temp against you're socket temp and measure the difference (should be somewhere around 8-10c different) then when you unlock you just go of the skt temp - you're difference calculated earlierto get you're estimated core temp, it's not perfect but it's as good as you are going to get when unlocked , the socket temp in HWmonitor is the reading called CPU
IMPG you got it
I actually assumed he was doing that, since he is reporting an ACTUAL temperature and not -255 which is what I have gotten (or 0c) on every chip I have unlocked ever).
I should know to never assume.
Glad someone pointed out the obvious.
Uh something else no considers.
What motherboard are you using? Seems to me it might be you are running too weak a mobo and those are actually motherboard temps.
Just because a board COMES with a feature does not mean it will work reliably. Especially since their maximum cpabilities are always in a very fine print IE.. TDP value of a motherboard. a 125W TDP chip unlocked to a 6 core, is not still a 125W TDP chip. If it was it would have been sold as a 6 core chip. What power the VRMs can provide must be considered and MOST ESPECIALLY, are they sinked fets or not. You can still burn up a sinked VRM dont get me wron but 98% (guess) of the ones I have seen are from overclocking or unlocking on a board that was really designed for ath2 quads or phen two duals.
