15 Case Fans Tested: Ultimate 140 mm Roundup
One question which frequently turns up on forums, “What’s the best fan?”, but even that question is too broad. Let’s tighten our focus to 140 mm case fans. They can move air through your case and stay reasonably quiet while they are doing that. So let’s look at a bunch.
140mm Collection
CPU heatsinks tend to come with their own fans. Even when a manufacturer like Prolimatech sells CPU heatsinks, it sells its own fan that coincidentally produces great results on its heatsinks. Among 120 mm fans, many are built for heatsinks, some are built for radiators, some are built for cases, and some are built for newbies. And there are a zillion kinds out there. So we will not try to review 120 mm fans here. That would take forever – and all the OEM’s would have to cooperate in the endeavor.
Cases tend to come with not enough fans. Or they come with barely enough fans, but you would like more. So there is a need for case fans. Also, many cases are made for 140 mm fans these days. Although there are some rads made for 140 mm fans, there are not many. So, without further ado, let’s introduce a 140 mm collection.
Specifications
We will introduce the fans and provide their specifications in one fell swoop:
Case Fan
Blade
No.
Bearing Type
Speed
RPM
Current
Amps
SP
mmH2O
Aerocool Shark 14
15
FDB
1500
0.36
1.1
Aerocool Shark 14 @7v
15
FDB
800
0.15
0.3
Antec True Quiet 140 H
9
na
800
na
na
Antec True Quiet 140 L
9
na
500
na
na
be quiet! Pure Wings 2
9
Rifle
1000
0.09
0.8
Enermax T.B.Silence
7
Twister
750
0.15
0.8
Evercool Red Scorpion
11
Long Life
1200
0.28
0.0
fractal design
Dynamic GP-14
7
Hydraulic
1000
0.2
0.7
Lian Li
LI121425BE-B4-A
11
na
na
0.14
na
Nanoxia
Deep Cool 140 mm
9
na
1100
0.14
1.1
Nanoxia Deep Cool
140 mm @7V
9
na
800
na
Noctua NF-A14 FLX
7
SSO2
1200
0.08
1.5
Noctua NF-A14 FLX
+NA-RC10 (LNA)
7
SSO2
1050
0.08
1.2
Noctua NF-A14 FLX
+NA-RC11 (ULNA)
7
SSO2
900
0.08
0.9
Noctua NF-A14
iPPC-24V-2000 IP67
7
SSO2
2000
0.1
4.2
Noctua NF-A14
iPPC-24V-2000@12 Volts
7
SSO2
1100
n.a.
1.2
Noctua NF-A14
iPPC-24V-3000 IP67
7
SSO2
3000
0.33
10.5
Noctua NF-A14
iPPC-24V-3000@12 Volts
7
SSO2
1800
n.a.
3.0
Noctua NF-A14 PWM
7
SSO2
1500
0.13
2.1
NF-A14 PWM + NA-RC7
7
SSO2
1200
0.13
1.5
Noctua NF-A14 ULN
7
SSO2
800
0.04
0.7
NF-A14 ULN + NA-RC11
7
SSO2
650
0.04
0.4
Noctua NF-P14s redux-900
9
SSO
900
0.07
0.8
Noctua NF-P14s redux-1200
9
SSO
1200
0.08
1.3
Prolimatech Blue Vortex 14
9
Sleeve
1000
0.2
0.8
Rosewill Hyperborea
140mm (PWM)
9
HDB
1300
0.21
2.8
Thermalright X-Silent
11
Liquid
900
0.14
na
XSPC Xinruilian RDM1425S
7
Sleeve
1350
0.23
1.2
Yate Loon D14SL-12
7
Sleeve
1000
na
na
140 mm Case Fans
Aerocool Shark 14 (Model #: A1425H12)
First up is the Aerocool Shark 14, a 15-bladed fan with a hydro-dynamic bearing. The Shark 12 and 14 have teeth on their fins, which may do something when the fan is moving slowly but only seem to make extra noise when the fan spins rapidly. The fan comes with a Molex-to-3pin power tap, along with a resistor line that provides 7 volts to the fan. The Results chart will show performance at 12 and 7 volts. I used this particular fan on its 7 volt adapter for years as an intake fan in the 5.25” bay of my first case. I have a photo-essay of installing it here, if you are interested.
Antec doesn’t seem to be featuring these on their website any more. However, you can still find them in a number of shops, since Antec did sell these at retail. Their main claim to fame is that they are cushiony and quiet. There is a little switch on a wire that sticks out from the fan. You can switch between high and low speed operation. Antec provided the fan for review.
Aerocool Shark 14
Aerocool Shark 14
be quiet! Pure Wings 2 (Model #: Q PUW2-14025-LS-10)
Next up is the be quiet! Pure Wings 2. This is the case fan that be quiet! use for their Silent Base cases, the 600 and the 800 (the links are to the reviews), so be quiet! indirectly provided the fans for review. Those corrugated blades are designed to enhance airflow. The cushions at the screw-holes are pretty nicely designed to reduce vibration transmitted by the fan to the case.
Enermax T.B. Silence UCTB14 (Model #: EA142512W-OAB)
This fan was advertised as having the same babatwinglade shape as the Cluster, the Everest, the Magma, and the 120mm T.B. Silence. But apparently at the slow speeds where this fan operates, the current blade shape was preferred at the time.
be quiet! Silent Wings 2
Evercool Red Scorpion EC-RSF-14 (Model #: EC14025L12EA)
This fan came in a blister pack and was bundled with a 140 mm to 120 mm reducer. Unlike some other OEM’s, Evercool actually makes fans.
fractal design Dynamic GP-14
These fans were pulled from the fractal design R5 that I reviewed last year. Thus they too were indirectly provided by the manufacturer. These fans did something I’d swear was impossible: they blew more air when they drew through the dust filter than they did when they were facing open air. For that reason, their results will be shown separately.
Lian Li LI (Model #: 121425BE-B4-A)
This anonymous fan is one I pulled from a case I bought for my daughter years ago. The reason we pulled it is because it shakes as it runs. It is the vibrating-est fan I have. But it lights up with pretty blue LED’s when it runs, and it does move air.
Nanoxia Deep Cool (Model #: DF14025SEDN)
The particular fans I tested were from the Nanoxia Deep Silence 5 I reviewed. But it wouldn’t have made any difference which case they came from, since Nanoxia uses the same model of fan in all their cases. They are attractive.
Lian Li 140 mm case fan
Noctua NF-A14
I have reviewed a number of Noctua fans, both as part of their heatsinks and by themselves (the most recent review is here). So all the fans tested in this review were sent directly by Noctua for review. The NF-A14 comes in a variety of speeds, both voltage-controlled and PWM. When the NF-A14 comes as an industrial PPC fan (hereafter abbreviated as iPPC), its frame is black.
There are also 24 volt versions of these fans. What stands out about this is that these fans were designed not only to run at 24 Volts, but to run at 12 volts as well.
For the NF-A14 FLX, the LNA is the NA-RC10, the ULNA is the NA-RC11.
For the NF-A14 ULN, the ULNA is the NA-RC11.
For the NF-A14 PWM, the LNA is the NA-RC7.
Although Noctua gives their airflow in metric, we will convert those specs to CFM.
Noctua NF-A14 in various forms
Noctua NF-A14 iPPC
Noctua NF-A14 iPPC
When Noctua brought out the “A” series of fans, they did not retire their older fans. Instead, they changed their colors and packaging. Noctua calls this their redux line. What makes this development doubly interesting is that they transformed the NF-P14 from a round frame to a square one. They still make round P14’s, but we will look at the square framed NF-P14’s. Again, these samples were provided by Noctua.
This is a sleeve bearing fan with a fixed speed that Prolimatech made for their heatsinks. Yet 1000 RPM should make this is an ideal case fan, and we will be testing it that way. Prolimatech provided one of the two fans that will be tested.
Rosewill Hyperborea 140mm (PWM) (Model #: ROCF-11003)
Rosewill is the house brand for Newegg. Generally, they have been a pretty good house brand. I bought the two we will be testing for a heatsink, since these are PWM fans. We will be looking at them as case fans.
Thermalright is an old name among heatsink manufacturers, but this is their entry into case fans. It’s an old entry, but it continues in the market. I included this in a review I did here.
Rosewill Hyperborea
Rosewill Hyperborea
Thermalright X-Silent 140
XSPC Xinruilian (Model #: RDM1425S)
This fan is made for XSPC for their 140 mm radiators. It was provided for review not by the OEM but by Koolertek. Although it is a sleeve bearing fan, it is a sleeve-bearing fixed-speed fan, it is sold for rads. We will be testing it as a case fan.
Yate Loon (Model #: D14SL-124B)
Yate Loon is famous for building inexpensive fans that beat out its higher-price competitors. Remember that shaky fan I pulled out of the Lian Li case years ago? We replaced it with one of these. Like that one, this fan has four cheery blue LED’s to brighten up the scene. Running five years without a glitch, it has not worn out yet, and I have barely heard it. Pretty good for a sleeve bearing fan.
XSPC 140 mm Rad Fan
XSPC 140 mm Rad Fan
Yate Loon 140 mm Low Speed
Setup for Testing
We have at least two of a number of the fans here. We can use this fact to demonstrate that specifications cannot be exact for any human-made object. We will look at the speed of these fans in RPM and the SPL in decibels. Then we will look at their output directly. So let’s get busy.
First up, the free air RPM and SPL. This was measured at 10 cm, and extrapolated to 1 meter by subtracting 20 dBA from the result. This makes quiet fans measure louder than they really are, but the alternative is trying to measure the noise they make when that noise is less than the 30 dBA bottom limit of the Sound Level Pressure meter, which in this case was a Tenma 72-942. The RPM was measured by the motherboard’s utility.
Next, the direct output. Measurement of a fan’s output is a matter of some discussion. You can find some mighty fancy gear designed to measure a fan’s output, but little of that is devoted to measuring computer fans. So, I thought about it and I looked at the tool I had to measure airflow. It is an Extech AN100, which has a 72 mm measurement head which contains a small fan that is driven by the airflow you are measuring. It actually measures velocity, but multiplies that by the area of the duct you are measuring. While the anemometer was built to measure the wind in big ducts, it will measure airflow in small ones too. It then averages ten readings and outputs in CFM.
Each fan was first mounted on top of a 140 mm rad, which fed into the mixing box. At 16 FPI, this rad is probably a good stand-in for most heatsinks, so you can get some idea of how these case fans will do in that situation. Each fan was then mounted directly to the mixing box, and covered by a metal mesh dust filter. You all use filters, right? Finally, each fan was allowed to blow unobstructed into the mixing box, an eight-inch cube. The anemometer head was put at the exhaust end, measuring the amount of air coming out. The box was sized to allow the fan output between the hub and the rim to mix before being measured. The profile of each fan will give you an idea of how much static pressure the fan has. With the 16 FPI rad and the dust filter along with the noise that it makes, you should be able to get an idea of which fan you want to use for what purpose.
NF-P14s redux on Rad
Blue Vortex Anemometer Setup
The results will be portrayed on a rather complex graph. You can either ignore the complexities and focus on the noise (in purple) and the unobstructed airflow (in red). But I think the other measures (through the rad, through the dust filter) may tell you things you want to know about each fan.
Results of Testing
These fans are arranged alphabetically by OEM. First we will look at them with all of their measurements on one chart. This will allow you to see the fans’ pressure profiles. Admittedly, this chart is a wee bit busy, so after this this we will break out the results, one at a time.
140mm - 7
140mm - 8a
140mm - 9a
All but fan one beat their specs. Only the Antec True Quiet had a lower SPL than specified. The Noctua fans all matched or beat their CFM specs. The Noctua fans were adjusted so that their SPL profile does not match our hearing profile. In that, I judge they were successful: they have roughly the same SPL as comparable fans with similar airflow, but my observation was that the tone of the Noctua fans are more pleasing to listen to and easier on the ears and did not sound as loud as you would expect from their SPL’s.
Arriving at the tail end of the alphabet, the last three fans were the most interesting. All three beat their CFM specs as well as being as quiet or quieter than advertised. Then there is the odd result – four Yate Loon fans averaged 57.9 CFM when pulling air through the dust filter. They averaged only 59.3 CFM when there were no obstructions. One of them measured 0.2 CFM more with the filter than unobstructed, which ratifies the result from the fractal design fans.
140mm - 10aFinally, we have those fractal design fans. When I obtained these results, I checked my equipment over very carefully. I retested. They stood: the fans drew more air when they had a filter in front of them than when they were obstructed by the filter. Maybe you can provide an explanation in the comments.
140mm - 4a
Conclusions
First of all, there ain’t no free. The faster a fan spins and the more air it moves, the louder it gets. Some fans manage to make their noise less obtrusive. Some fans just plain make more noise. Then there is the price you pay for fans.
The purpose of a collection like this is to present you with data. It doesn’t matter what the absolute value of the measurements are, although these are reasonably accurate. What matters is that these measurements were all done on the same equipment. This allows you to compare them.
There is no one fan that is the champion of all the fans. There are only fans that have various properties, fans that fit your purposes and needs.
In the end, all of these are good fans.
Ed Hume (ehume)
About Ed Hume 75 Articles
Ed Hume has been a contributor to the Overclockers.com community for over 10 years. He has written nearly 100 reviews and guides mostly focused on cooling. His scientific and technical approach to analyzing airflow, temperatures, heatsinks and fan performance have made him a fan favorite. In one of his well-known fan roundups, he compared the performance of over 60 fans at once, now that's dedication to the craft!
Loading new replies...
Avatar of ssjwizard
ssjwizard
Has slightly less legible writing than Thideras
5,583 messages 149 likes
Interesting and through review. I only use my 140s for radiator usage so of little benefit to me, but glad someone took the time to go out of the box and do a proper review on the 140s!
Reply Like
Avatar of HankB
HankB
1,222 messages 21 likes
Thanks for such an extensive and thorough review. :thup:
Reply Like
Avatar of t1nm4n
t1nm4n
700 messages 0 likes
have you ever tried pulling through a rad, or is there not much difference? A question about eh Noctua 3k rpm fans, you tested 24v version, is that model only 24v? I've only seen them listed as 12v 3k rpm fans, was curios how those would line up, or are they only 24v and retailers have them mislabeled?
Reply Like
Avatar of ssjwizard
ssjwizard
The 24V fans will operate at either voltage. There should be a spec sheet somewhere that shows what the different speeds are at each voltage.
Reply Like
Avatar of EarthDog
EarthDog
Gulper Nozzle Co-Owner
76,751 messages 3,447 likes
This roundup mentions those details, as well as his review. :)
Reply Like
Avatar of magellan
magellan
2,118 messages 145 likes
It would've been nice to have seen some 140mm x 38mm fans thrown into the mix. I have one 140mm x 38mm (an expensive SanAce 109P1412M101). I ended up using it as an exhaust fan, although I always wanted to use it on a heatsink.
Reply Like
Avatar of t1nm4n
t1nm4n
I guess I just skimmed more than I thought I did.
So the only question I have is, will (or think) you have the chance to test the NF-A12 12 3k fan and NF-A14 12v 3k fan, those would be some interesting numbers to see, especially the noise, which I'm sure at 3k is gonna be an earful.
Reply Like
Avatar of JrClocker
JrClocker
AKA: JrMiyagi
2,457 messages 130 likes
You guys got this right!
The data posted showed that the Noctua NF-A14 FLX was quieter and moved more air than a 140 mm Noctua iPPC PWM at 1550 RPM when used as a case fan (i.e. pulling against a filter).
I bought 2 NF-A14 FLX based on the data...and much much quieter...and cooler temps.
:thup:
Reply Like
Avatar of ehume
ehume
874 messages 1 likes
I was looking at the 140's as case fans. I threw in the 140mm rad when I realized it was 16FPI. They made the rad for 800rpm quiet rad fans. I was mainly looking at how well these fans will pull against a dust filter. The sparse rad simulates a heatsink.
If I ever get a real 30FPI 140mm rad, you can bet I'll test those Noctuas. But pushing on a rad is much easier to test than pulling. You can permanently attach the rad to your mixing box and swap fans. This is easy. Pulling through a rad requires you to fasten the fan directly to the mixing box, then attach the rad to the fan -- think fan sandwich here. Doable, but a pain. And you probably end up with a destroyed box.
I suppose you could use the current rig but reverse the airflow -- just measure the air you pull into the box. For some reason, I'm a little leery about that. But i'll think about it if I ever get a "real" 140mm rad.
I've seen that San Ace. I've lusted after that San Ace. But the cheapest I could find it was $59 US -- a little steep for a fan I would test but never use.
If I can ever get some more 140mm case fans together -- think Corsair, Deepcool, Phanteks, Thermaltake, etc. -- I'd certainly do another roundup. Now that I have a testing system together, I'm curious.
Reply Like
Avatar of JrClocker
JrClocker
AKA: JrMiyagi
I have 4 of the 140 mm Prolimatech Vortex (red) setup in push/pull in my Corsair H110i GTX radiator. The radiator has a very high FPI (21 I believe), so I need 4 to get the airflow.
If Noctua had a flashy looking red fan like the Vortex, I replace these in a heartbeat with the NF-A14 FLX because they are so quiet...even though the Vortex are pretty quiet! (Nobody believed me on my "I think I'm in love" thread in this section...hehe!
I was using the Noctua iPPC-2000 PWM fans as intake case fans. I just had to get them 1550+ RPM to get enough air flowing through the case...and they are loud at that RPM.
The NF-A14 FLX are running at 1200 RPM as case intake fans...and pretty quiet...moving more air than the iPPC-2000 PWM fans at 1550 RPM.
Everybody thought I was crazy...but your data shows the same as mine!
:thup:
Thanks again...my home office no longer sounds like a server room! :D
Reply Like
