ADATA Legend 970 PCIe Gen5 x4 M.2 SSD Review
It’s September of 2023, and we finally have our next PCIe 5.0-based M.2 storage module for review. ADATA was kind enough to send the Legend 970 in 1TB flavor. The new drive utilizes a Phison E26 controller with speeds listed up to a blistering fast 10,000 MB/s on reads and writes (2 TB version) and comes with its own heatsink and active cooling to help prevent throttling. Read on to see the specifications and see how the 1 TB performed in our test suite.
ADATA Legend 970 1TB
Specifications and Features
The ADATA Legend 970 boasts two sizes, 1 TB and 2 TB, driven by Phison’s PS5026-E26 controller. The 8-channel controller boasts sequential read and write speeds up to  10,000 MB/s for reads and writes, respectively. The version on the test bench runs up to 9,500 MB/s and 8,500 MB/s on writes. The 232-layer Micron TLC flash is supported by 2 GB of Hynix DDR4 DRAM running at DDR4-2666 and 4GB on the 2 TB. MTBF (Mean Time Before Failure) is listed at 1.6 million hours, while the TBW (Terabytes Written) value is 1,400. The latter isn’t as much as some (the MSI we just reviewed was 3,000 TBW). However, I wouldn’t worry about surpassing that value through its usable life. It also includes TRIM functionality, SMART, AES-256 encryption, and more.
ADATA Legend 970 Pro Specifications
ModelLegend 970 Pro
Capacity1 TB2 TB
ControllerPhison E26
Flash3D NAND (232-layer Micron)
DRAM Cache2GB DDR44GB DDR4
Form FactorM.2 2280
InterfacePCIe Gen5 x4, NVMe 2.0
CompatibilityPCIe Gen5/4/3
Dimensions (L x W x H)80.6mm (L) x 24.00mm (W) x 17.9.15mm (H)
Sequential ReadUp to 9,500 MB/sUp to 10,000 MB/s
Sequential WriteUp to 8,500 MB/sUp to 10,000 MB/s
Random Read 4KB (IOPS)Up to 1,300,000 MB/sUp to 1,400,000 MB/s
Random Write 4KB (IOPS)Up to 1,400,000 MB/sUp to 1,400,000 MB/s
Max Operating Power (W)9.510.7
Idle Power (W)2.22.2
Low Power L1.2(W)4.9
Operating Temperature0°C – 70°C
Storage Temperature-40°C – 85°C
Endurance (TBW)7001400
Mean Time Between Failure (MTBF)Up to 1,600,000 Hours
Advanced FeaturesTRIM (Performance Optimization, OS Support required)
SMART (Self-Monitoring, Analysis and Reporting Technology)
AES256 (Encryption, Data Security)
Warranty5 Years, or the coverage for the maximum TBW as stated, whichever comes first.
Pricing (MSRP)
1 TB $1902 TB $330
Packaging
The retail packaging on our Legend 970 is a simple box with plastic inside to hold the drive in place. The front shows a picture of the drive along with some high-level information, including the model and capacity. The back of the box lists several certifications along with serial numbers and a QR code to easily access the drive details.
ADATA Legend 970 - Retail Packaging.
ADATA Legend 970 – Retail Packaging.
ADATA Legend 970 - Retail Packaging (rear).
ADATA Legend 970 – Retail Packaging (rear).
Retail Packaging Contents
The ADATA Legend 970 M.2 SSD
The Legend 970 is a dual-sided drive, as are many others these days. Our sample came with its heatsink on top and, when removed, fully exposes the controller and ICs below (no sticker removal). Flipping the drive over exposed more of the NAND and has QR codes for additional information.
A Closer Look
Zooming in on the drive, we get a better look at the Phison PS5026-E26 controller in silver towards the business end of the drive. The 2 GB SKHynix DDR4 DRAM IC is next to that. ADATA uses four Micron 232-layer 3D TLC NAND chips that run at 2,400 MT/s to make the 1 TB capacity. Since all the spaces are taken up on the PCB already, the 2 TB model uses higher-density NAND.
Software
ADATA’s SSD Toolbox is a comprehensive application to monitor and control your ADATA (and other brand) SSDs. The colorful software displays drive information, diagnostic scans, system information and optimization, benchmarks, and even has some cloning capability. Overall, it works on our ADATA drives without issue and presents users with plenty of information and options on configuration.
Testing Method and Test System
We have recently updated our testing procedure and have tested a variety of drives with this new methodology. The changes include switching the setting in Crystal Disk Mark from default to its NVMe settings. This provides results that a more in tune with today’s standard as we test more NVMe drives than SATA drives. The other change we made was to eliminate the external temperature probe. This decision was based on the fact that most PCIe Gen 5 drives require some form of cooling, generally in the form of a heatsink. We have found the probe mounted between the controller and the heatsink naturally affected the heatsink’s ability to cool the drive. Previously, we only included the heatsink in the results if the drive was throttling. Going forward, we will use the drive’s internal thermal sensor, as reported by HWinfo64, with the product’s included heatsink installed. If none was provided, then the test rig motherboard’s included heatsink will be used.
Below are the tests we run with a brief description.
  • Crystal Disk Mark v8.0.4 x64 – Set to NVMe Settings (5 Passes)
  • AS SSD v 2.0.7316 – Run at Default Settings
  • ATTO v4.01 0f1 – Run at Default Settings except for the QD Set to 10
  • Thermal Testing  (HWinfo64 v7.46-5110)– Monitored throughout testing
  • DiskBench v2.8.1.0 – Use predefined 120 GB transfer file
  • Anvil Storage Utility Benchmark v 1.1.0 – Default Settings
Test System
Test System
Testing System
MotherboardGigabyte Z790 Aorus Extreme
CPUIntel i9 13900K
CPU CoolerEVGA 3x120mm AIO
MemoryADATA XPG 32GB DDR5-6000 CL32
OS SSDCrucial T700 1TB
Power SupplyEVGA 850W P6
Graphics CardEVGA RTX 3080 FTW3
All tests will be performed with the drives installed in the CPU-connected PCIe 5.0 x4 M.2 socket to utilize the direct CPU interface.
Benchmark Results
CrystalDiskMark
CrystalDiskMark is the premier benchmark for verifying an SSD’s advertised speed. Depending on the test, our Legend 970 did well overall, matching or beating the Corsair Gen 5 drive and easily beating out the PCIe 4.0-based Legend 960 1TB in most tests. Remember, we’re using the 1TB drive which has slightly slower specs than the 2TB Corasair. Overall, this benchmark shows a performant drive, though the random 4K 1T tests were a lot lower in this test system.
AS SSD
Similar to CrystalDiskMark, AS SSD tests the drive’s abilities in sequential and 4K read and write tests. Here, our Legend 970 did well in 4K results, beating out the other Gen 5 drive along with most others. The sequential reads and writes were slower than the Corsair MP700 (Gen 5) in this test as expected with the 1 TB option. Nothing to worry about here.
AS SSD - Writes
AS SSD – Writes
AS SSD - Reads
AS SSD – Reads
ATTO
The ATTO benchmark utilizes a file size spectrum to gauge speeds based on the file’s relative size. Here, our drive again beat out the Gen 4 devices as expected and slower than the 2 TB Corsair.
ATTO - Reads
ATTO – Reads
ATTO - Writes
ATTO – Writes
Anvil’s Storage Utility is another benchmark that measures read and write speeds, similar to CrystalDiskMark and AS SSD. The main difference with ASU is that it produces a performance score for comparison rather than an actual speed. This performance score is more of an all-encompassing overview of the drive’s capabilities. We don’t see anything unusual from ASU either.
Anvil Storage Utilities
Thermal Testing
Thermal testing on our Legend 970 was sourced from the ADATA software, as HWinfo did not read the temperatures on the drive. As you can see, the actively cooled Gen 5 drive ran a lot cooler than the previous Gen and the other hot-running Gen 5 drive in the test group. Worth noting the tiny fan on this heatsink is loud. You will hear it over your chassis cooling. As of now, there doesn’t appear to be any way to adjust the speed to lower the noise.
Temperature Testing
Temperature Testing
DiskBench
Moving on to DiskBench provides us with a great, real-world test. It was designed to determine actual file transfer time. Using a 120 GB file composed of random data, we transfer the file from the primary (OS) drive to the test drive, recording the actual transfer time. If you do a lot of large file transfers, this is the test to pay attention to.
Diskbench
Diskbench
Diskbench results have our drive in third place behind a Gen 5 and, surprisingly, a Gen 4 drive as well.
Conclusion
The ADATA Legend 970 1 TB proved to be one of the fastest M.2 drives we’ve tested so far and competes well with our other PCIe 5.0-based M.2 module in the Corsair MP700, even though it’s the 1 TB version and a bit slower. The 2 TB version is the direct competition. Still, we saw some solid results throughout our testing, showing it’s typically more performant than any Gen 4 drives we’ve tested as expected. We’ll gather more data as the drives become available for testing.
The Legend 970 comes with its own heatsink that works well and keeps the drive running cool enough that it didn’t throttle in our longer-running tests and transfers. In other words, it functions great. That said, the fan is fairly loud and sings with a high pitch, so it was quite audible over the chassis fans and AIO used in our test system. I’d like to see the curve changed a bit so that it stays quiet, at least on idle, or maybe offering some control, even if it’s pre-defined modes, through software.
Priced (MSRP) at $190 for the 1 TB version we’ve reviewed and $330 for the 2 TB version, it’s expensive compared to last-gen drives, but that’s to be expected. Compared to other 1 TB drives, it is competitive with prices ranging from around $180 up to $220. 2 TB PCIe 5.0-based M.2 modules range from around $300 to $400 dollars. In short, the Legend 970 at both 1 TB and 2 TB capacities is reasonably priced in the market as well. Overall, we like what the ADATA Legend 970 has to offer. Just make sure you don’t need silence in your build if you don’t plan on changing the heatsink.
Click here to learn what this means
Joe Shields (Earthdog)
Related Articles:
About Joe Shields 341 Articles
Joe started writing around 2010 for Overclockers.com covering the latest news and reviews that include video cards, motherboards, storage and processors. In 2018, he went ‘pro’ writing for Anandtech.com covering news and motherboards. Eventually, he landed at Tom’s Hardware where he wrote news, covered graphic card reviews, and currently writes motherboard reviews. If you can’t find him benchmarking and gathering data, Joe can be found working on his website (Overclockers.com), supporting his two kids in athletics, hanging out with his wife catching up on Game of Thrones, watching sports (Go Browns/Guardians/Cavs/Buckeyes!), or playing PUBG on PC.
Loading new replies...
j
jarablue
62 messages 4 likes
Whats with all these gen5 nvme only getting to 10k reads? Shouldn't the read speed be more than that? Or is this what we should expect for now from lackluster brands?
Reply Like
W
Woomack
Benching Team Leader
14,250 messages 3,823 likes
Some go up to 12.5-12.8k (Crucial, Corsair, Team Group), but it depends on the firmware and SSD design. Controllers are all the same Phison E26. Random bandwidth is almost the same on all of these SSDs. It's only sequential bandwidth which is different.
Reply 1 Like
Avatar of Blaylock
Blaylock
8,114 messages 1,108 likes
...Also, I would not consider ADATA to be lack-luster.
Reply 1 Like
j
jarablue
62 messages 4 likes
I had horrible experiences with adata.
Reply Like
W
Woomack
ADATA may not be the top brand, but it has kept relatively high quality for years. They look pretty good, especially when you compare quality to the price. There are always issues with some single products, and every manufacturer has problems from time to time. The main difference between most brands is how their support reacts and what they offer to solve the issue.
Reply 3 Likes
