Alphacool
Table of Contents
Today, Alphacool announced the Eisbaer Pro Aurora series All-In-One CPU cooler line-up. The Eisbaer Pro Aurora features a larger cooling plate and mounting system for compatibility with some of the largest CPUs on the market including AMD’s Threadripper, Intel’s LGA3647, LGA4189, as well as fitting the new LGA1700-based systems. Full copper NexXxoS ST30 radiators in 280 mm and 420 mm are available and feature quick-release couplings for expandability. For complete details, continue reading Alphacool’s press release.
Alphacool today presents the Eisbaer Pro Aurora 280mm & 420mm CPU AIO
Alphacool Eisbauer Pro Aurora
Alphacool’s Eisbaer Pro Aurora CPU “all-in-one” solution is now also available with 280mm and 420mm radiators.
Bigger is better! The Eisbaer Pro Aurora has been developed specifically for large CPU DIEs. It fully covers AMD Ryzen and Threadripper processors as well as Intel’s Socket LGA 3647 and 4189, allowing for the best possible cooling performance of the entire CPU. Intel’s new LGA 1700 socket is also compatible with the Eisbaer Pro and is perfect with this AiO. As with all Eisbaer AIOs, Alphacool uses the NexXxoS ST30 radiator with cooling fins, pre-chambers and cooling channels all made of copper as well as the robust TPV hoses with quick-release couplings from the ENTERPRISE Solutions series. With the help of the quick couplings, it is possible to integrate other common water cooling products such as GPU coolers into the water circuit. For this range the new 140mm Rise Aurora fan has been used. The PWM-controllable fan allows speeds from 0 – 2000 rpm and impresses with its brilliant aRGB LED illumination.
Thanks to an included adapter, Alphacool’s Eisbaer Pro Aurora CPU AIO is already compatible with Intel’s LGA 1700 socket. The socket is expected to be launched in November of this year.
Alphacool Eisbaer Pro Aurora 280mm & 420mm CPU AIO
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Today, ID Cooling announced its latest CPU air cooler, the SE-226-XT. The new cooler has two SKUs available. One for ARGB lovers and an all-black version for those anti-RGB consumers. ID Cooling claims up to 250 TDP cooling capabilities and includes mounting hardware for all modern mainstream platforms. Pricing is set at a very reasonable $39.99 for the black model and $44.99 for the ARGB version though availability will be dependant on your region. Here is ID Cooling’s press release.
Early this morning, Phanteks announced three new models to its Glacier One series All-in-One CPU liquid coolers. The MP Halos Glacier One Black models will be available in 240, 280, and 360 mm versions. These coolers maintain the same features and performance as the original Glacier One cooler but are now available with Addressable RGB lighting on the fans. Pricing starts at $149.99 and will be hitting the shelves in the coming days. Below is Phanteks press release with additional information.
Montech just launched the Metal DT24 premium and Metal DT24 Base dual-tower CPU coolers, along with a Metal 120 mm PWM fan. The coolers feature six copper heat pipes measuring six millimeters thick with a fin stack and cooling base made of copper and aluminum. Montech claims an impressive 270 Watt TDP which would make it one of the best Air coolers on the market. The Premium variant receives a decorative top plate and ARGB lighting, while the Base version comes in silver and black without lighting.
Today, Alphacool announced the Eisbaer Pro Aurora series All-In-One CPU cooler line-up. The Eisbaer Pro Aurora features a larger cooling plate and mounting system for compatibility with some of the largest CPUs on the market including AMD's Threadripper, Intel's LGA3647, LGA4189, as well as fitting the new LGA1700-based systems. Full copper NexXxoS ST30 radiators in 280 mm and 420 mm are available and feature quick-release couplings for expandability. For complete details, continue reading Alphacool's press release.
Loading new replies...
