Table of Contents
Today, Biostar announced a pair of B560 mATX motherboards for Intel’s 10th/11th Gen processors, the B560MX-E PRO and B560MH-E PRO. These business-to-casual use motherboards have remarkably similar features including connectors for two M.2 4.0, four SATA III (6GBs), two PCIe 4.0, as well as WiFi 6. The main difference between the two is the lack of a DVI-D port on the B560MH-E PRO motherboard. Pricing and availability have not been disclosed at the time of this writing so if you’re interested in a light use or business class motherboard, follow the links at the bottom of this press release.
BIOSTAR ANNOUNCES THE LATEST B560MX-E PRO AND B560MH-E PRO MOTHERBOARDS
Best B560 Chipset motherboards in the market
April 30th, 2021, Taipei, Taiwan – BIOSTAR, a leading manufacturer of motherboards, graphics cards, and storage devices today, announces the latest B560MX-E PRO and B560MH-E PRO motherboards.
Designed to support Intel’s 10th/11th Generation Intel Core™ Processors and professional graphics cards, the new B560 series motherboards are highly versatile. Powered by Intel’s B560 chipset, these two new motherboards are efficient and robust in any use case.
PCI-e 4.0 and PCIe M.2 4.0 & M.2 Cooling, among other cutting-edge technology, adds up to a great platform, tailor-made for business or even casual use. The two new motherboards support up to 128 GB of DDR4 memory across 4 DIMM with an overclocking capability of up to 4000+(OC)Mhz.
Backed by BIOSTAR’s proprietary Digital PWM technology, the new B560MX-E PRO, and B560MH-E PRO motherboards are safe and long-lasting, capable of supporting the best hardware with ease. Both motherboards pack all the essentials in their rear I/O panel with almost identical layouts on a Micro-ATX form factor.
Designed with 6 USB ports consisting of 4 x USB 3.2 (Gen1) Ports and 2 x USB 2.0 Ports. Furthermore, a single 1 x PS/2 Keyboard / Mouse Port provides extra connectivity for users looking to use an older device with the system.
Additionally, 2 x WiFi Antenna ports that support WiFi 6 and a single LAN port powered by Intel® I219V chipset are readily available in these two motherboards for faster internet connectivity. When it comes to video connectivity, the B560MX-E PRO motherboard comes with a single DVI-D port which is not available on the B560MH-E PRO motherboard.
Both motherboards share a single VGA-Out port in addition to an HDMI 2.1 port capable of supporting up to 4k vivid crystal-clear images. Three powerful audio ports controlled by the ALC897 chipset provide an immersive audio-visual experience.
Overall, BIOSTAR has once again delivered two outstanding products for their consumers. Reliability, performance, and cutting-edge technology makes the new B560MX-E PRO and B560MH-E PRO motherboards the best choice for any business or casual use.
Spec table:*
Model
B560MX-E PRO
B560MH-E PRO
Chipset
Intel® B560
Intel® B560
CPU SUPPORT
Support for
10th/ 11th Generation Intel® Core™ i9/ i7/ i5/ i3 processors and Intel® Pentium® processors/ Intel® Celeron® processors in the LGA1200 package
* Please refer to www.biostar.com.tw for CPU support list.Support for
* Please refer to www.biostar.com.tw for CPU support list.MEMORY
Supports Dual Channel DDR4 2933/ 2800/ 2666/ 2400/ 2133
4 x DDR4 DIMM Memory Slot, Max. Supports up to 128 GB Memory
Each DIMM supports non-ECC 4/ 8/ 16/ 32GB DDR4 module
* Please refer to www.biostar.com.tw for Memory support list.Supports Dual Channel DDR4 2933/ 2800/ 2666/ 2400/ 2133
* Please refer to www.biostar.com.tw for Memory support list.STORAGE
— Total supports 2x M.2 socket and 4x SATA III (6Gb/s) ports
4 x SATA III Connector (6Gb/s) : Supports AHCI, RAID 0, 1, 5, 10 & Intel® Rapid Storage Technology
1 x M.2 (M Key) Socket (M2_PCIEG4_64G_11TH_ONLY):
Supports M.2 Type 2280 SSD module
Supports PCI-E 4.0 x4 (64Gb/s) – NVMe/ AHCI SSD
Support 11th Gen processor only
1 x M.2 (M Key) Socket (M2_PCIEG3_32G_SATA_RST1):
Supports M.2 Type 2242/ 2260/ 2280 SSD module
Supports PCI-E 3.0 x4 (32Gb/s) – NVMe/ AHCI SSD & SATA III (6Gb/s) SSD
Supports Intel® Optane Technology
* M.2 (M Key) Socket (M2_PCIEG4_64G_11TH_ONLY) support 11th Gen Rocket Lake-S CPU only.— Total supports 2x M.2 socket and 4x SATA III (6Gb/s) ports
* M.2 (M Key) Socket (M2_PCIEG4_64G_11TH_ONLY) support 11th Gen Rocket Lake-S CPU only.LAN
Intel® I219V
10/ 100/ 1000 Mb/s auto negotiation, Half / Full duplex capabilityIntel® I219V
10/ 100/ 1000 Mb/s auto negotiation, Half / Full duplex capabilityAUDIO CODEC
ALC897
7.1 Channels, High Definition Audio, Hi-Fi(Front)ALC897
7.1 Channels, High Definition Audio, Hi-Fi(Front)USB
6 x USB 3.2(Gen1) port (4 on rear I/Os and 2 via internal headers)
6 x USB 2.0 port (2 on rear I/Os and 4 via internal headers)6 x USB 3.2(Gen1) port (4 on rear I/Os and 2 via internal headers)
6 x USB 2.0 port (2 on rear I/Os and 4 via internal headers)EXPANSION SLOT
1 x PCIe 3.0 x1 Slot
1 x PCIe 4.0 x16 Slot (x16 mode)
1 x PCIe 3.0 x16 Slot (x4 mode)1 x PCIe 3.0 x1 Slot
1 x PCIe 3.0 x16 Slot (x4 mode)REAR I/O
2 x WIFI Antenna Port
1 x PS/2 Keyboard/ Mouse Port
1 x VGA Port
1 x DVI-D Port
1 x HDMI Port
4 x USB 3.2 (Gen1) port
2 x USB 2.0 port
1 x LAN port
3 x Audio Jack2 x WIFI Antenna Port
1 x VGA Port
1 x HDMI Port
2 x USB 2.0 port
1 x LAN port
3 x Audio JackINTERNAL I/O
1 x M.2 (E Key) Socket : Supports 2230 type Wi-Fi & Bluetooth module and Intel® CNVi
2 x USB 2.0 Header (each header supports 2 USB 2.0 ports)
1 x USB 3.2 (Gen1) Header (each header supports 2 USB 3.2 (Gen1) ports)
1 x 8-Pin Power Connector
1 x 24-Pin Power Connector
1 x CPU Fan Connector
1 x CPU water cooling connector (CPU_OPT)
1 x System Fan Connector
1 x Front Panel Header
1 x Front Audio Header
1 x Internal Stereo Speaker Header
1 x Clear CMOS Header
1 x COM Port Header
1 x TPM Header
* M.2 (E key) Wi-Fi card is not provided4 x SATA III Connector (6Gb/s)
1 x COM Port Header
1 x TPM Header
* M.2 (E key) Wi-Fi card is not providedDIMENSION
uATX Form Factor, 244 mm x 244 mm
OS SUPPORT
Windows 10(64bit)
* Biostar reserves the right to add or remove support for any OS with or without notice.Windows 10(64bit)
* Biostar reserves the right to add or remove support for any OS with or without notice.ACCESSORIES
2 x SATA Cable
1 x Rear I/O Panel for ATX Case
1 x Quick Guide
1 x DVD Driver2 x SATA Cable
1 x Quick Guide
1 x DVD DriverRead more about B560MX-E PRO and B550MH-E PRO here:
B560MX-E PRO: https://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=1014
B560MH-E PRO: https://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=1015
ABOUT BIOSTAR
BIOSTAR, is a professional brand dedicated to the production of motherboards, gaming motherboards, SSD, graphics cards, industrial computing systems, IoT, crypto mining equipment, healthcare solutions and motor start battery. Since its establishment in 1986, BIOSTAR has become a major motherboard supplier in the IT industry. In order to pursue the best quality and aesthetic design, BIOSTAR has invested heavily in ID design, equipment, global marketing research as well as R&D. With a constant emphasis on quality, BIOSTAR always seeks to improve beyond better and race to the future.
Recent Articles
No replies yet
Loading new replies...
