ASUS hosted another live stream today for CES 2022. This one focused on its ProArt and ZenScreen series portable displays, ZenWifi networking devices, and a pair of mini PCs. The ASUS ROG live stream from yesterday was primarily gamer-oriented, today’s was targeted at the business and content creation sectors. In total Asus announced 10 new products for 2022. Dates and prices are not included in the press release, so stay tuned to the front page news section as we will report back once these are officially announced. Below are the featured products from ASUS’s second live stream.
CES 2022: ASUS Launch Event Products
Monitors/Displays
ProArt Display PA169CDV
ProArt Display PA169CDV is a 15.6-inch 4K UHD IPS portable monitor that includes Wacom EMR technology for pens. Built for professional creatives, it offers stunning 4K resolution and is targeted VESA DisplayHDR 400. Two innovative kickstands offer users versatile experiences. The upper kickstand is designed to be closer to the keyboard (and Adobe shortcuts), and the lower kickstand can be used for a second display monitor.
ProArt Display OLED PA16DC
ProArt Display OLED PA16DC is a 15.6-inch 4K (3840 x 2160) UHD HDR monitor with OLED panel. It offers 10-bit color, covers 100% DCI-P3 color space, and has a 1,000,000:1 contrast ratio to provide the deepest black and the brightest white hues. ProArt Display OLED PA16DC is targeting VESA DisplayHDR 400 True Black and it includes ASUS Smart HDR technology to support multiple HDR formats and PQ curves. A built-in colorimeter provides effortless calibration experiences to help ensure long-term color accuracy. The colorimeter can also be used for SDR and HDR calibration with the bundled ProArt calibration software, which provides seamless integration with third-party software such as Calman and Light Illusion ColourSpace CMS. The display has a hood designed to reduce reflections and incudes two different stands to fit different scenarios.
ProArt Display PA348CGV
ProArt Display PA348CGV is a 21:9 UWQHD (3440 x 1440) display that is pre-calibrated for Delta E < 2 color accuracy. It is Calman Verified and features a 120 Hz variable frame rate to provide smooth 2D/3D rendering. An ergonomic design allows users to easily adjust the monitor for a better viewing angle. Including two types of monitor stands for different scenarios, it allows users to choose either a traditional monitor stand or a C-clamp desk mount to best utilize desk space.
ZenScreen Ink MB14AHD
ZenScreen Ink MB14AHD is a 14-inch IPS panel with dual touch functionality. It offers 10-point touch and an active stylus pen for writing. An integrated kickstand enables variable scenarios in the office, at home or outdoors. It comes with an MPP2.0 stylus pen that is precise with 4096-level pressure sensitivity and low latency for exceptional writing experiences.
ZenScreen Go MB16AWP
ASUS ZenScreen Go MB16AWP is a 15.6-inch Full HD IPS anti-glare wireless portable monitor that’s equipped with a high-capacity battery. Built-in wireless connections eliminate external cables, enabling you to stream a movie from your smartphone, or project a presentation from another device. An Auto-rotation (with G-sensor) automatically senses orientation and switches the display between landscape and portrait, based on its position. A new kickstand design provides users with flexibility for comfortable use in a variety of scenarios. An embedded ¼” thread at the bottom of the monitor allows users to attach it to a standard tripod to save desktop space.
ASUS BE24ECSNK
ASUS BE24ECSNK is a 23.8-inch Full HD (1920 x 1080) IPS monitor with an integrated 2-million-pixel FHD (1920 x 1080) webcam and mic array, making it ideal for videoconferencing and remote learning on Microsoft Teams, Webex, Google Meet, Zoom and other popular applications. The built-in webcam offers tilt (–10°, +10°) and swivel (–135°, +180°) adjustments, allowing users to ensure they stay in frame, no matter their position.
ASUS BE24ECSNK
Networking
ZenWiFi XT9
ZenWiFi XT9 is a tri-band WiFi 6 mesh router systems designed to provide whole-home WiFi coverage in a stylish, space-saving format. ZenWiFi XT9 offers WiFi speeds of up to 7800 Mbps, with 160 MHz channels for better efficiency and throughput. Using the latest Broadcom WiFi 6 chipset, RangeBoost Plus leverages multiple exclusive Broadcom technologies to dramatically improve WiFi signal range and coverage by up to 38%. In addition, extending to the 5.9 GHz Band (UNII 4), which is the only DFS-free 5 GHz range band, makes room for the 160 MHz channel with higher power. Moreover, ZenWiFi XT9 includes commercial-grade security with AiProtection Pro powered by Trend Micro, for safe internet connections.
ZenWiFi XD5
ZenWiFi XD5 is a dual-band WiFi 6 mesh router featuring 160 MHz bandwidth. The delicate size (90 x 90 x 80 mm) blends easily into any environment while delivering great performance, not to mention it is wall-mount-friendly. Designed as a whole-home mesh system, it takes you only three steps to set up and provides parental control functions such as URL filter and scheduling, allowing you to protect your family from inappropriate content and unhealthy usage.
Mini PC
PN52
The new ASUS Mini PC PN52 is an ultra-compact and lightweight mini PC that’s ideal for a wide range of uses, including home and business applications. Measuring just 120 x 130 x 55.5 mm, Mini PC PN52 blends easily into any environment while delivering great performance. Comprehensive I/O ports and support for up to 4 displays ensures versatile connectivity and flexibility to handle almost any conceivable display scenario. Mini PC PN52 features Two-Way AI Noise Cancelation for crystal-clear online voice communication.
PN64
The new ASUS Mini PC PN64 is an ultra-compact and lightweight mini PC that’s ideal for a wide range of uses, including home and business applications. Measuring just 120 x 130 x 55.5 mm, Mini PC PN64 blends easily into any environment while delivering great performance. Up to 4 displays are supported. Comprehensive I/O ports also provide versatile connectivity for docks and storage devices, including 5 USB ports and one optional port. Mini PC PN64 features Two-Way AI Noise Cancelation to ensure crystal-clear online voice communication. For even more flexibility, the chassis design enables easy storage and memory upgrades in just two steps.
ASUS PN52 and PN64 Mini PC
OMAP (OPTO-MECHANIC APPLIED PRODUCT)
TUF Gaming TF 120 case fan
The TUF Gaming TF120 ARGB combines high airflow, low noise, durability and style to become more than the sum of its parts. This fan has been tuned specifically for chassis inlet and outlet use. It delivers a class-leading (for ARGB fans) 76.5 cfm at just 28.5 dB, and its fluid dynamic bearing is rated for up to 250,000 hours of smooth operation. To help tackle noise, each corner of the frame has an anti-vibration pad ― a feature normally reserved for higher-end fans. At the same time, PWM control allows for a wider RPM range, so the fan can spin at very low speeds and will even turn off when the duty cycle is at 0%. Meanwhile, 16 ARGB LEDs are strategically divided into two layers to provide higher color saturation (on the blades) than competing ARGB fans, and they also enable an array of lighting effects. The 3-pack of TF120 bundles an Aura Sync ARGB hub to control these effects, which features a magnet on one side for easier installation and cable management.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
The ASUS R9 series of graphics cards are starting to roll in to Overclockers, and today we have a chance to look at their R9 270X DirectCU II Top edition. All the familiar ASUS features we’ve come to expect from one of their enthusiast level video card are present and accounted for in this release. Armed with the DirectCU II cooler, DIGI+ Super Alloy Power, and the TOP factory overclock this offering should perform quite well. Right on the box it says “In Search of Incredible.” Let’s see if we found it
With all the refreshed X99 based motherboards releasing due to the Broadwell-E launch we see a new contender from ASUS, their X99 Deluxe II. The original X99 Deluxe, then X99 Deluxe/U3.1, were range-topping motherboards for the ASUS Signature series and the new board is as well. Let’s take a look at all the features, both new and old, of the X99 Deluxe II before checking out the performance!
With the release of the new Haswell line of CPUs, motherboard manufacturers are rolling out motherboards to support the new socket 1150 platform. Overclockers’ very own hokiealumnus recently published a review on ASUS’ top dog for this platform, the Maximus VI Extreme. Today however, we’ll tone it down a bit and review one of ASUS’ Z87 entry-level mainstream motherboards – the Z87-A. If you’re looking to get into the Haswell game at an affordable price, does ASUS have something worth your consideration in the Z87-A? Let’s find out!
ASUS hosted another live stream today for CES 2022. This one focused on its ProArt and ZenScreen series portable displays, ZenWifi networking devices, and a pair of mini PCs. The ASUS ROG live stream from yesterday was primarily gamer-oriented, today's was targeted at the business and content creation sectors. In total Asus announced 10 new products for 2022. Dates and prices are not included in the press release, so stay tuned to the front page news section as we will report back once these are officially announced. Below are the featured products from ASUS's second live stream.
We use cookies to ensure that we give you the best experience on our website. If you continue to use this site we will assume that you are happy with it.OkPrivacy policy
No replies yet
Loading new replies...
