CES 2022: EVGA Introduces RTX 3050, X12 Mouse, and XR1 Pro Capture Card
EVGA
EVGA
EVGA has just launched three new products during our CES 2022 coverage. First up is the RTX 3050 XC and RTX 3050 XC Black entry-level Graphics cards. Built on Nvidia’s Ampere architecture the RTX 3050 is designed to offer Ray-Tracing performance at a budget anyone can pallet.
Next, the X12 gaming mouse that was unveiled uses a 32-bit Arm Cortex-M33 core USB microprocessor with a native 8000Hz report rate. This allows for the reading of precise movements more accurately than the average gaming mouse.
Finally, the XR1 Capture Card is a streamer or content creator’s best friend. Capable of pass-through resolutions of 1440p at 144hz or 4k at 60 Hz, connections for multiple video, audio, and controller devices, make the EVGA XR1 Pro perfect for streamers, gamers, or work conferences. Here is what EVGA says about its latest devices.
Introducing the EVGA GeForce RTX™ 3050
January 4, 2022 — Introducing the EVGA GeForce RTX™ 3050 gaming cards, designed to bring the best ray tracing gaming experience at an irresistible price for gamers and creators.
The new EVGA GeForce RTX™ 3050 brings the performance and efficiency of the NVIDIA Ampere architecture to more gamers than ever before and is the first 50-class desktop GPU to power the latest ray traced games at over 60 fps. The RTX™ 3050 comes equipped with 2nd generation RT cores for ray tracing and 3rd generation Tensor cores for DLSS and AI. Ray tracing is the new standard in gaming and the RTX™ 3050 makes it more accessible than ever before.
EVGA RTX 3050 XC Black
EVGA GeForce RTX™ 3050 XC / XC BLACK
The EVGA GeForce RTX™ 3050 cards punch above their weight with the latest Ampere GPU, 8GB of GDDR6 VRAM, and a 14GHz memory clock to enable solid performance even at 1440p. The XC Series tradition continues with a shorter PCB, dual-slot cooling and a quiet, zero decibel fan mode, making the EVGA GeForce RTX™ 3050 a perfect choice for the entry level gaming users.
The EVGA GeForce RTX™ 3050 XC is designed for gamers ready for the next tier of performance. Efficiently designed to be cooled with two large fans and protected with an all-metal backplate, the EVGA GeForce RTX™ 3050 XC is carefully packaged into a short two-slot card for maximum compatibility with all types of gaming cases.
EVGA RTX 3050 XC
EVGA RTX 3050 XC
The EVGA GeForce RTX™ 3050 XC BLACK features a streamlined designed, letting its performance do all the talking. Excelling in games and productivity with 8GB of GDDR6 memory, the GeForce RTX™ 3050 XC BLACK offers creators and gamers everything in a small package without the need for a bulky cooler to ensure cool, smooth performance.
Introducing the EVGA X12 Gaming Mice
EVGA X12 Gaming Mouse
January 4, 2022 — Introducing the EVGA X12 Gaming Mice, the latest entry to EVGA’s X Series Gaming mice. Equipped with a USB 2.0 High-Speed 32-bit Arm Cortex-M33 core USB microprocessor, supporting a native 8000Hz report rate, eight times the standard 1000Hz on competing gaming mice, ensuring precision accuracy.
Dual sensor configuration, LOD(Lift Off Distance) sensor paired with a Pixart 3389 optical sensor, the X12 uses an advanced 2-DIMENSION ARRAY TECH to achieve precision readings. Allowing you to fine tune the sensor shut off height.
New Light weight ambidextrous body, flexible paracord usb cable, and low friction PTFE mouse feet to allow fast reactions and quick flicks.
Full control and customization with EVGA Unleash RGB software. Customize and load up to five custom profiles to the onboard memory for taking settings on the go
EVGA X12 Gaming Mice also supports NVIDIA Reflex Analyzer, giving competitive gamers an accurate measurement of system latency for the first time.
Introducing the EVGA XR1 Pro
EVGA XR1 Pro
EVGA XR1 Pro
January 4, 2022 —It’s time to stream like a Pro with the new EVGA XR1 PRO Capture card. Capture every game play moment like it’s meant to be with true 1440p@144fps / 4K@60fps Pass through. Stream instantly lag free or capture and record up to 4K@30fps and share to the world.
EVGA XR1 Pro
EVGA XR1 Pro
Effortless setup to get you streaming immediately. Simple plug and play, no driver installation required.
EVGA XR1 Pro
EVGA XR1 Pro
Connect a camcorder or DSLR camera to set up web conference, meetings, lectures, or seminars for up to 4K@30fps video quality.
EVGA XR1 Pro
EVGA XR1 ProEVGA XR1 Pro
Customizable RGB LEDS and built in audio mixer controls at your fingertips with the EVGA XR1 PRO control dial.
The EVGA XR1 PRO is certified for OBS™. OBS™ is a free and open source software for video recording and live streaming. Download and start streaming quickly and easily.
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of Overclockers.com
3,227 messages 223 likes
EVGA has just launched three new products during our CES 2022 coverage, the RTX 3050 XC and RTX 3050 XC Black entry-level Graphics cards, the X12 gaming mouse, and the XR1 Capture Card.
Click here to read more!
Reply Like
