2x512 Corsair pc3200 small problem
caRpetbomBer
416 T dot
When i use 2x512meg sticks of corsair pc3200 in my NF7-s rev2.0
Doesn't matter if i have it in single channel or dual. My computer does not like it at all. Prime crashes like after 5 hours. With one stick prime is stable forever.
I use the 19 bios. 10x200fsb with all different timings and voltages to the ram. Any ideas whats up.
Anyone heard of corsair not working properly in a NF7-S rev2.0
which corsair pc3200 is it?
if it's ll try 2-3-2-6
another thing that could cause prime to crash is cpu instability, your board should be fine (maybe try increasing vcore)
btw, i'd use either d10 bios or v20 if I was you
The ram is CMX512-3200c2 v1.2
The reason i don't want to use the bios 10 is cause i have a raid and I'm afraid of corruptions.
I tried like super relaxed timings and everything.
The settings i use now are 100% stable but when i add the other stick its bad news.
I have always heard, two sticks of corsair 512 3200 don't clock as well as one stick does. It kept me from upgrading my memory. When I do, I think i'll go with a single gig stick.
yes, but his one stick aint even working @ spec, or even below spec...
just check your timings, i had problems with it too for a bit then i adjusted mine and it works great, rock solid for months now. below are my timings and setups. corsair pc3200 works great. also is it xms or the budget stuff?
V
Yeah its XMS. I'm going to have to setup another system or get another hard drive cause every-time i install the other stick of ram in my system i get BSOD. I want to test the stick by it self. And not kill my raid setup that i just installed. Funny thing is i had the system working for the longest time with both sticks @10x200 2.5-3-3-11 default everything less.
Thanks guys
I found the problem.
I made a boot-able cd of memtest.
i got over 10000 errors with the other stick of ram i guess that means its toast. ROFL
