memtest86+ still freezes but blend runs fine (only tested 11 minutes)
i ran it from different usb ports and flash drives
also memtest86+ reads cas as 4-5-5-18 which is off by a lot
any further suggestions (don't suggest removing memory because my family member's 1055t runs 16gb fine on a gigabyte 880g board)
But what you don't know is if one of your four ram sticks is bad or if one of your four slots is bad. You'd need to be willing to test each of both of those one at a time to really rule that out.
I believe the motherboard is bad, the ram (both 8 gb 1333 and 16 gb 1600) I have tested and they passed before (when I just built the PC); the chances of all the sticks going bad or both imcs going bad are rare
Bumped for relevance:
Could any of you folks recommend what offset to use for Coretemp on the FX-8150? Cheers
