Thanks IM!
That particular file didn't do the trick, but searching around bootdisk.com led me to an answer...a link to M$'s site, where I hit paydirt (so to speak...it's running, and Folding, so I guess that's paydirt, right?
In part, from M$'s site....:
"SUWIN General Protection Fault" Error Messages During Windows 95 or Windows 98 Setup (Q224836)
The information in this article applies to:
Microsoft Windows 98
Microsoft Windows 95
Microsoft Windows 98 Second Edition
SYMPTOMS
When you try to install Windows 95 or Windows 98 in a new folder or a clean hard disk, you may receive one or more of the following error messages:
SUWIN caused a general protection fault in module KRNL386.EXE
CAUSE
This behavior can occur when any of the following conditions exist:
There are incorrect basic input/output system (BIOS) settings for a built-in peripheral device on your motherboard (for example, cache settings, CPU timing, hard disks, and so on).
Your computer has bad or mismatched random access memory (RAM) or cache (for example, if you are using EDO and non-EDO RAM, or you are using different RAM speeds).
The motherboard in your computer is not working properly.
RESOLUTION
To work around this behavior, try to slow down your computer by changing the BIOS settings. For information about how to change these settings, consult the documentation that came with your computer or contact the hardware manufacturer.
WARNING : If you change the BIOS settings for your computer incorrectly, serious problems can occur.
NOTE : Make the following changes, one at a time. After each change, save the setting, quit the BIOS, and then try to run Setup. If one step does not resolve the problem, try the next step, and so on.
Modify the bus mastering setting.
Modify the externalor internal cache setting.
Modify your RAM setting.
Modify other settings that are specific to your BIOS and that contribute to the speed at which your computer runs.
Disable the Level 1 and Level 2 cache from the BIOS Setup tool for the duration of Setup.
Disable the Ultra DMA setting (if applicable) for the hard disk or CD-ROM drive. For information about how to change these settings, consult the documentation that is included with your computer.
If the error message still occurs after you perform these steps, the hardware may be damaged. Contact your hardware manufacturer for assistance
Those points in bold, are what I did. I backed off on all the settings, even from the "fail-safe" in the BIOS.... I disabled the L1 and L2, backed the ram off to 100MHz/PC1600 speed, disabled UDMA support for all drives, etc...
I then tried to install Windows again....I got past that point at which I was hanging, and getting the "SUWIN" error. Windows setup showed an approxamate setup time of 147 minutes though....lol.
I shut down, and enabled the L1 and L2....started the install again, fresh format and everything. Installed.
In 30 minutes. =)
Gotta be the DDR ram. It's running like a champ at the moment, with the ram underclocked... I'm gonna let it run for a while, and try to enable UDMA support to the drives first. If it flies, that narrows it conclusively to the ram.
Which runs fine on my MSI, and Shuttle. Curious
Gotta be that damn generic DDR....
At least it's running.... Thanks to those who helped with their thoughts and suggestions...esp. IM, for sending me to bootdisk....that was the key that unlocked this 8KHA+.
