- Oct 8, 2001
- Charleston, WV USA
Hey all,
While I have been overclocking for some time I am new to AMD processors.
I have an Abit kg-7 raid mb so I am using softmenu III to do the overclocking.
Here are my questions:
1. It is not clear from other posts if an Athlon 1.4 266FSB is locked or unlocked. Does anybody know whether I need to connect the L1 bridges? If I up the multiplier from 10.5 to 11 in Softmenu it will not post. Just BSOD when Win2k starts up. The processor does show 1600Mhz when the computer is booting. Does this mean that it's unlocked but just wont handle any overclocking?
2. I am running rock solid right now at 1499 MHz by just upping the FSB to 143. Whats the difference in doing it this way vs the multiplier. Voltage is at 1.775 I believe. I just moved it up one increment in Softmenu.
3. At the above settings 143FSB and 1.775 V I am running at 123F per the Via hardware monitor. How hot is too hot?
Forgive me if I am asking redundant questions, I tried to find specific answers by searching old posts but I wasn't getting anywhere. If anybody with a similar setup can recommend settings to me I would appreciate that as well.
My main concerns right now are temps and the multiplier problem. If I have simply gotten a processor that isn't up to OC'ing that's OK but if I am doing something incorrectly I want to figure it out.
Thanks in advance!
Thanks in advance!
