- Feb 1, 2011
- Republic of Texas
What wonderful engineering. Thanks for all your work Shawn.
We've seen two pics at 5.4 GHz already... not that it changes things much.3 ) subzero cooling on avg 4.8-5.0 ghz and max of 5.1-5.3 ghz
The 3900X is 12-cores and the 3800X is 8-cores so there's a big difference between the two chipsIs there going to be a big benefit to going with the 3900x over the 3800x if I want to try and both play games and stream at the same time?
Hoping to see a nice bump going from my 1600 @ 3.7GHz.
Has anyone successfully slipstreamed the new AMD Zen2 drivers into their Win 7 x64 install ISO yet?
The trusty ol' Ryzen Edition ISO obtained from hwbot no longer works properly on X570 mobos, it probably needs the new USB drivers.
I'm running 1.0,0,2 which fixed what you're seeing. The system would boot but RAM was a mess. XMP didn't work nor did manual settings
it runs really hot with P95, like 80C with Noctua D9L.
Did a little bit of monkeying around today with the 3900X and The X470 CHVII
Managed to get 3800 memory pretty much stable at CL 16, 30 minutes AIDA64 memory stability test and a bunch of benchmarks. I also have it running 1:1 so no latency penalty.
Guess you are still too caught up in the new launches for the time being, would appreciate if you can link/share the ISO when you are less harried for time.You're correct and I haven't had time to dig them up.
Psh. That's still like 15 degrees cooler than my 9900K
