Alaric
- Dec 4, 2011
- Satan's Colon, US
No it does. Read the Ryzen Master guide. SenseMI gets disabled once the multiplier is set over stock. Also, since CC states are disabled, the only way to engadge power savings is through P-states.There was some interesting information in the latest Ryzen Community update that explains something odd I had noticed. My current board doesn't have P-state settings, so I figured it would use a lot more power at idle if I overclocked in the bios. But, strangely, after setting the frequency in the bios, idle power consumption didn't appear to be any higher at all, even though all cores were now pegged to 3.9 GHz. It seemed like even though it claimed it was running at that speed, it was still clocking down behind the scenes.
Well, it turns out that is exactly what is happening. The chip can still enter "CC states" regardless of what P-state Windows is set to. Which also means that locking out the P-state with an overclock doesn't really make much difference.
True, but my understanding from the document is that internal voltage control via senseMI is disabled when overclocking, at least that is what the document says. There are definitely more than one way to skin a . [emoji14]@Nagork, BF
You can still lower power by not changing frequency. There are a lot of advanced power gating at work in modern x86 architectures. Even though the "core" frequency has not reduced, other parts of the core may be turned off or put into some sort of low power state.
True, but my understanding from the document is that internal voltage control via senseMI is disabled when overclocking, at least that is what the document says. There are definitely more than one way to skin a ��. [emoji14]
Will the power savings options work if folks only change the multiplier and adaptive voltage?
