- Aug 23, 2006
That thing is really really sharp. I wish I could do work like that. Great Great job.
WeezleXX89 said:ok that is a kickass nice looking case. you just spray painted it and thats all. how many fans do you have? thats a nice looking case. if i gets too hot will the paint melt? tell me the steps. i want that case. O have a question about water cooling. If i plan on getting a coolermaster case, does the mobo have to support the cooling or is it the power supply. I dont really know much about cooling. can you tell me the basics. thanks for you help.
Ace Epoxy Enamel was the brand I used.gocartman2 said:im def doing this to the inside and back of my lexa, i need to switch some water cooling around anyways
and i own at spray paint, i really need not explain
small, didnt want to hijack
ive worked with all brands, but may i asked which paint you used, i know its high gloss, or semi...
i might go laqer on mine
Senater_Cache said:rust-oleum professional high perf enamel gloss black will own all paints short of montana or molotov.
gave a clear coated-like finish after 2 coats!
I just screwed old standoffs in from the back and went paint happy. Let the paint cure before removing them.Senater_Cache said:hey rig rider, when youpainted the mobo tray, did you mask off the thread-holes for the standoffs?
im worried that layingon a big coat with them opened, that they will clog and my standoffs will get stuck or not even fully screw in.
watcha do?
Thanks.Rattle said:that is really sweet, nice job and nice av also
Give that man a prize! ....................Milla Jovovich........Huba, Huba.Rattle said:its the 5th element and resident evil girl isnt it
