D5 pumps are not intel spec'd PWM and only run at a max 60% I've heard. If there's no PWM signal, by default a fan or pump will run at 100% but in the case of the 3rd party D5s, they might just be running at 60%.
How is the flow looking in the reservoir? Is it wavy or splashy or calm looking? Based on those right there, I can give a rough estimate of your flow rate. For example, when I'm 0.5 GPM and under, the flow in my dual bay reservoir looks calm. At 0.7+ GPM, it looks wavy. At close to 1.5 GPM, it looks splashy like a hurricane in there but than again, all of this means nothing if your reservoir isn't similar to mine so take this with a grain of salt.
