- Oct 19, 2008
I think the problem might be because I unplugged the jumper and foregot to put it back on before booting the first time. I feel that I may have to reset my bios. how do I do that?
I am using a jumper to bypass the feature. I get normal stuff like express gate not installed, not hdd detected. all this is fine because I did not install express gate and I did not put my hdd in because i was testing to make sure all is well before I put more parts in it.
after the normal stuff it says fatal error, and then something like chassis intrusion
What is going on?
can i disable the feature in bios?
do I need to update my bios?
What is going on?
