I'm not sure which 'same issue' you mean (maybe the price point? of course that's only becaue NV did a drastic price drop on 9800GTX) but again you limit the comparison to one other card as if the two exist in a vacuum, why? That comparison technique only works for fanboys who refuse to buy a card from the other company. Also setting up criteria such as '$400 to spend' (it seems more like you mean 'you HAVE TO spend $400
) when there are only two choices at that approximate price (9800GX2 looks to be higher actually) just predetermines what the choice will be because there are only a few options. It's not necessary to spend as much as possible you know
so saying that a less expensive item is another choice for 'up to $400' not only opens up options but saves money too.
The 9800GX2 is not worth $100-150 more than the 4870
by your own logic either and yet you seem to recommend it as a better buy than the 4870, which is just a natural conclusion saying 'if you have $400 to spend,' or rather 'you have to spend $400.' The inconsistency in the application of your logic is what does not make sense unless there's another motivation behind it.
