Super Nade said:
I personally do not own any expensive DDR2, but I think all this angst and confusion can be eliminated if you can tell us the difference in average performance between the two IC's.
Since I've never done any comparisons myself, I can't answer that. According to Apps Lab (
http://www.houseofhelp.com/forums/showthread.php?t=55347):
Apps Lab @ HoH said:
Actually, the PROMOS stuff can frequently clock to 1000 MHz @ 5-5-5 latencies @ 2.2V. It's decent overclocking memory. That's a 20% gain on the stock speeds, and I think having that kind of headroom is fairly decent.
Note: Before commenting on this quote, people, please read that whole thread leading up to his quote. That way, you have the full context around his statement, it's a fair request
DerekT said:
They changed chips and did NOT update their site.
It's called the IC
INQUIRY Thread for a REASON. You have to INQUIRE about your IC in order for it to be LISTED! If it was supposed to be a fullly documented list of every IC they used, don't you think it would be on their website, and not in the forum, and maybe even say that it's a fully documented list of all of their ICs?
Oh, and you really need to stop assuming things. Like for instance, that I work for Corsair. Umm... No. I don't. My first post on this forum (it's in this thread) I SPECIFICALLY stated that I don't work for Corsair. I've said it MULTIPLE places @ HoH. Corsair has stated multiple places around HoH that I don't work for them. Also, all of the Corsair staff there say that they are in their user title in one fashion or another. The only way you'd know that I'm part of the HoH Forum staff is either by reading my sig (which no one ever does), or by reading the forum leader page, which also has a separate area that lists Corsair employees. To Super Nade, Silversinksam, and the rest of the staff here, sorry for that rant
OrionRU: If your sticks don't work at the rated timings, like Silversinksam said, RMA them. You can fax, call, e-mail, post on the Corsair forum, or fill out one of two different forms to start the RMA process with Corsair. Link to a summary of the various ways:
http://www.houseofhelp.com/forums/showthread.php?t=52317
