Maybe. Remember every card is different. What one can do, yours may not.Looks like I can downvolt even more then.
What are the clocks?
1080 and 1485 - mining Vertcoin. Haven't really tried overclocking yet.
I'm more interested in stability and low temps on this card than getting the best performance now.
Def gotta look into that Woomack. Just got mine back from RMA...
1150 core, 1500 mem.. 13.12 catalyst kalroth cgminer
Code:del *.bin cgminer.exe --scrypt -o stratum+tcp://mine.coinshift.com:3333 -u 1Gi3MdL7pVzwCE5VG9eATCj17iSGv9uG6i -p x --thread-concurrency 8193 -w 256 -X 4 -g 2 --no-submit-stale
@Luke1978 , your settings are working pretty good but only with overclocked card. Actually I can set lower core clock and it doesn't change much. My memory can't run @1500MHz , max is ~1450MHz what gives me ~480 kh/s.
What is weird, the same settings at stock clocks give me ~350kh/s, big difference for not so much higher memory clock.
So now it looks like 1100 core , 1450 memory , core voltage lowered to 1.1V and 480-485 kh/s. So far it's working for about 4h without errors.
480 Kh is the most I've seen out of a 270.
You might get more Kh if you can run the core a bit more, but 480 is pretty much the tops I think.
Nice work!
No matter if I set 1100 or 1200MHz on core I get about the same results, +/- 5kh/s.
I see 500kh/s when I set memory higher at about 1500MHz but it crashes pretty quick.
try this miner: http://k-dev.net/cgminer/
then try the following settings, bare with me
xintensity 4 (yes no intensity setting, xintensity replaces it)
gpu-threads 2
I noticed that cards up to the 7 series work great with the older cgminer, but 7 series and up are a bit twitchy, prolly bc cgminer's old approach is more brute force
He is using those settings
EDIT: Raw intensity would be the next step to get more Kh, but I'm just getting the hang of using raw intensity
lol sorry, must have missed the transition
Watch me curse myself:
My downvolted Asus 270X is so far now the most stable it's ever been. It's still running within one degree of the Asus 270. Currently both cards are doing 233khs each on Vertcoin.
In a couple days when my 4GB 270X shows up, it'll be moving to the office rig and joining my HD6870. Hope I can get them to play nice together.
There is no option to raise memory voltage in my card and I don't want to change much in this card as maybe I will sell it. It also has warranty sticker and I actually care about warranty when it's mining
I was checking lower clocks and at 1000MHz core / 1450 memory it still makes ~475 kh/s. What is weird, sometimes when I run cgminer I have lower hash rate like 350. Then I have to restart pc and it back to normal speed. It's not after driver crash or something. Also sometimes desktop/window manager stops and restarts.
I have no option to lower core voltage below 1.1V. I didn't try other soft than ASUS so far.
I thought that I will be able to close this rig in a smaller case but temps are going up too much and it gets loud. I have to figure out how to make it quiet.
