- Jun 18, 2001
- Winston Salem NC
I am a bit confused as to what I need to do after I set the task to working daily
Christoph said:It's beta testing time!
I think that my length tester works correctly, but I want some beta testing done.
edit: Woah. You brought skip back from the dead. Cool trick.
edit2: I should also note that the script does no kind of checking how the sig will look at 800x600. Instead it assumes you have an infinitely wide monitor. I've got one. They're pretty cool.
while ($line ne "") {
#size_open, /\[size=(\d*)\]/i
if ($line =~ /^\[size=(\d*)\]/i) {
$line =~ s/^\[size=(\d*)\]//i;
$size_tag = $1;
print "found a size tag on line $curr_line: $size_tag\n" if $debug;
#size 1 = .75 points
#size 2 = 1 point
#size 3 = 1.5 points
if ($size_tag == 1) {
$curr_size_tag = .75;
} elsif ($size_tag == 2) {
$curr_size_tag = 1;
} elsif ($size_tag == 3) {
$curr_size_tag = 1.5;
} else {
print "Warning: large size tag found on line $curr_line: $size_tag\n";
$curr_size += 100;
$using_tag_size = 1;
[color=yellow]$curr_size = max($curr_size_tag, $size_tag);[/color]
$size_state = $curr_size_tag;
Clean_Baldy said:I just realized that my computer isnt updating when it runs the program...
the numbers keep staying the same.
Any ideas?
FizzledFiend said:test it how? I know less about codeing as i do women and god knows they are elusive to me.
sig for 02/04/2005, 07:34 is:
sig for 02/04/2005, 15:00 is:
sig for 02/05/2005, 05:00 is:
sig for 02/05/2005, 08:06 is:
JerMe said:Can you post your sig_gen file? I'm not sure if your stats are pulling from EOC's html page or the xml page, but yeah it seems like you're sig is 50 WUs outdated. Good Lord, you have more points this week than I have TOTAL.
Clean_Baldy said:here is the link to my file:
http://jeff.jonrosensystems.com/sig_gen.pl
when i run it manually, it says "checking to see if sig should be updated:" and it says NO!
Hopefully that is a clue to what needs to be fixed
FizzledFiend said:added .txt so i could upload it..obviously just drop that off...I never done anything to this so maybe here is where the problem is?
also is there something I am suppose to do in my usercp here on the board?
Clean_Baldy said:
