in question about how the copper is mounted, i used the exact same size drill bit as the copper pipe, and its held with JB weld around the joints, so its suspeded about 0.3 of a cm above the plater
dyzio: did kill a few by the looks of things, as cannot get a full
partition, and there are about 2,000 bad sectors, which isnt really that many.
UnseenMenace: the piping is not what i am going to use, but was really a test to check for what materials i could use, and it seemed the easiest way.
iamthegreatest: i dont think any type of tubing apart from finned would work all that great, but as you say, its a prototype
also, BIG thanks to everybody who likes my ongoing mods, and im glad people appreciate them, and about the patent, this is NOT to stop any of you using my ideas, but i would rather me make nothing out of it than a big company make millions
Cheers, Turando
