- Sep 14, 2012
- AMD land
not to be mean. GOOGLE. you have to know your system
AMD didn't drop the ball on anything, your board simply lacks any type of useful Load-Line Control. Raising PLL voltage can help combat the symptoms of vdroop/low vcore and load stability. I'm not an engineer so I can't really explain how the PLL would affect stability that way but I've confirmed this phenomenon with several people in the past.Too much anything burns your CPU.
Intel typically sets the PLL too high..
AMD has dropped the ball on PLL voltage on the FX processors-- You basically HAVE to increase PLL voltage to get a good OC beyond 4.8GHz, and it makes a smaller OC easier with less core voltage.
It is a lot less stressful on your CPU than continuing to increase voltage Give it a shot when you have time. Best way to increase cpu performance overall is the following:
1. Increase CPU Frequency
2. Increase NB Frequency (Not as important on FX as Thuban / Deneb)
3. Increase FSB (Don't do this until you get familiar with multiplier-only OC)
I do all 3 when I OC. This also requires you to be able to monitor multiple variables at the same time, on the fly (Which is terrible for somebody asking for a cookie cutter OC solution)
Lets get you a stable OC before worrying about diving deeper into the game, alright?
Thanks tungrureanu.the issue was the folowing(if i remember correctly):"after he raised vcore, the system became unstable to a point that it not even post , after adding 2 bumps on it vcore. from what i remember the max was 4-4.2 and it whould boot. anything past that post failed. +the board has 4+1(if i remember correctly) power phases. wich in my opinion and experience is not really enough for a OC`d 8150.
Please correct me if i`m wrong about the power pahse part.
"Not just a single fish for a meal but Fishing Lessons by "trents" for a lifetime of meals. With these CPUs you would need to be concerned with and deal with certain things when overclocking..."
The above quoted accomplishes all of this post without confusing the user and simply having the screenshots report the data to the "experts". The user is now actively involved in solving the problem, knowing exactly what variables we're looking at right off the bat and having already looked at them himself. At this point, if the user has any questions as to what these do, he is able to ask. With the other methodology, the user simply starts some programs, takes a screenshot and posts them here, and other users go "You need to change vcore to 1.xxv", the user goes "Okay, but I still have the problem"..."What is your Core Voltage, CPU-NB Voltage, DRAM Voltage, DRAM Frequency, CPU and CPU-NB Frequency, HT Link Frequency? These can be found with a program CPU-Z*link* and HWMonitor*link*. Also, can you give a whole list of your computer specifications and components? You can put these in your signature with this format:
*signature template*"
I know people here are only trying to help each other. I ask questions too sometimes, because as in any case, if I can't figure something out on my own or I'm stumped, I'll ask someone else. This is how the world works...and this forum is here so we can all help each other.Don`t forget everyone here is trying to help each other. As for RGone he has followed th thread from post no.1 to post nr 160, and he told you what he thinks/knows as a guy who folowed the whole thing.
...Yes, I didn't read about it the first time, however I did think that if that wasn't covered, I'm afraid a new motherboard wouldn't help. Obviously it was covered so I don't understand why people would get butthurt over what I said, but do you do realize, there were about 120 of these 160 posts that were all bullcrap, because people were too quick to take random stabs at the problem?Ok. Did you read about the throttleing (OCP/OHP)? On the other thread you wrote
"In that thread, I did not read the whole thread but I did state as follows:" here "Because of this, I've read every post in this thread to see what was happening. It took almost 15 minutes. " BUT thats not the point. The point is as folows . The mobo has 4+2 power phases. yes it can handle a STOCK fx8150, maybe even a slight OC. but he want to go enthusiast on the 8150 and get as much as he can. IF he watercools the VRM`s maybe he can do it, BUT a single CPU wc loop is minimum 120E(here in the EU). Maybe he gets it stable somehow while a fan is blowing on the heatsink, but what will he do when the wear on the vrm`s is too much to take and he sees magik smoke and fire(perhaps 1 week after warranty expires), ain`t it just better to rma it and sell it (or keep it as backup) , and get a board that is adequate for his needs?
On Intel IMHO they dropped the ball on PLL voltage. When up around 54x multi+ it's a must to have PLL Overvoltage enabled and/or add PLL voltage...
With LLC enabled, upping PLL volts isn't going to do a whole lot for AMD Phenom II and FX, whether on air, or LN2. I've tested from 2.5 to 2.8v on air/water/LN2.
Now, I've missed 9 pages of discussion here and it seems the only solution or advice that's been given was for the OP to buy a new motherboard. Unfortunately, I think he will find that a new motherboard does not change things for him very much.
If the OP was only having the issue "ILLEGAL SUMOUT" as described in post #4, then the only thing that will solve the problem is more vcore at load, either by reducing any vdroop that may be occurring or raising vcore significantly all together. If a new motherboard has better LLC options (not sure what LLC does on the M5A97 R2.0, though I've tested the 1st version), then it will be more overclocker friendly (better calibrated Load-Line options), but outside of that there is nothing wrong with the board.
hi there, i need some advice on oc 8150, i'm not an expert in the field of oc. anybody using almost same as mine. right now planning to buy h100 to replace my cm v8, with only using multiple to clock up 8150 to 4.2 gzh. Any suggestion. i truly appreciate if somebody can tell me from zero basic.
thanks
http://imageshack.us/photo/my-images/84/49709923.png/
MOBO : ASUS CROSSHAIR V FORMULA
CPU : AMD 8150
CPU COOLER : CM V8
POWER SUPPLY : CM 750
GPU : ASUS DIRECT CUII 6970
MEMORY : CORSAIR VENGENCE 12 GB (3 STICK, BURN 1 SLOT)
HDDs/Optical drives: 4.5 TERA, SATA DRIVE, NO RAID
SOUND DEVICE : Onboard
USB > RAZER TRON KEYBOARD, RAZER NOSTROMO, ALIEN G9, LOGITECH G700, AND ROCAT
O/S : WINDOW 8 64 BIT
Case > Brand/Model/Fans Installed?
