- May 25, 2003
- Basking Ridge, NJ
http://www.sidewindercomputers.com/delffb1212eh.htmlsqueakygeek said:
An 120mm fan that does 190cfm? Could you post a link?
[EDIT: typos fixed]
[EDIT: typos fixed]
from here
Also note the power requirements of the FFB1212EHE, there is a 3.00 amp startup requirement too.
Banyan said:so would, say, a truepower 380 have problems with two of these things??
You're not seriously considering putting these in your case...Banyan said:so would, say, a truepower 380 have problems with two of these things??
JKeefe said:You're not seriously considering putting these in your case...
They run at 59dB. That will cause permenent hearing damage over time. You do not need 190CFM in a desktop case. That is overkill.
CrashOveride said:I suppose... its still only 3 decibles louder than a tornado...
Just find a bad assed pot and stick it on.
would this work?
http://www.allelectronics.com/cgi-bin/category.cgi?category=470015&item=RHE-25&type=store
A light dimmer might work... or would the fan be too powerful
Amorphus said:3db louder is twice as loud, dude.
login211 said:so is this a slk800a or slk900a?? topic says slk900 but your post says slk800a....
squeakygeek - the +10=*2 thing isn't for decibels, unless its a different scale. we use db(A) here.
I've heard the +10=*2 for brightness of stars, but thats about it... (there probably more)
Because of the wide range of pressure stimuli, it is convenient to measure sound pressures on a logarithmic scale, called the decible (dB) scale. Although a decibel is actually a means for comparing two sounds, we can define a decibel scale of sound level by comparing sounds to a reference sound with a pressure amplitude 2x10^-5 newtons per square meter, assigned a sound pressure level of 0 dB.
So, a noise seems twice as quiet or twice as loud every 6 dB it changes. In the computer world, if your fan seems twice as quiet after you turn it down, its SPL has dropped by 6dB.It is worth reviewing the difference between sound pressure level, sound power level, and sound intensity level, since all three are expressed in decibels ... Sound power level expresses the strength of the source, irrespective of the location of the source and the observer. Sound intensity level expresses the rate at which energy flows across a unit area. For a free progressive wave, the intensity is proportional to the square of the sound pressure. Thus, a doubling of the sound pressure results in an increase of 6 dB in sound presure level, whereas doubling the sound power increases the sound power level by only 3 dB. Similarly, a ten-fold increase in sound pressure represents a 20 dB increase in sound pressure level, but a ten-fold increase in sound power increase the sound power level by 10 dB.
Sound level meters have one or more weighting networks, which provide the desired frequency responses. Generally three weighting networks are used; they are designated A, B, and C. The C-weighting network has an almost flat frequency response, whereas the A-weighting network introduces a low-frequency rolloff in gain that bears a rather close resemblance to the frequency response of the ear at low sound pressure level.
Measurements of sound level are usually made using the A-weighting network; such measurements are properly designated as L(A) or SPL (A) in dB, although the unit dBA or dB(A) is often used to denote A-weighted sound level ... Inside a building, the C-weighted sound level may be substantially higher than the A-weighted sound level, becasue of low-frequency machinery noise, to which the ear is quite insensitive.
