- Thread Starter
- #21
EDIT: guess this is LLC set to extreme raising the vcore maybe?
Do I monitor that vcore at cpuz or hwinfo? Amd master seems very wrong, and hwinfo and cpuz show different.Yes LLC on extreme will bump the vcore up a little. Which is good. You need the current for the clock speeds.
At 4300Mhz you'll be at or over 1.5v.
I use Gpu-z sensors tab and HWInfo64 seems to work ok.
Probably should list my system specs for ya...
2700X Asus Prime B450M-A 16GB Corsair Vengence C15 3000Mhz. Stock Cooler.
One issue is there hasn't been a bios release for system memory stability/compatibility yet, so I get stuck running some pretty loose timings at 1333Mhz.
_____________________________________________________________________
So anyone's goal with a Ryzen Processors is to achieve maximum clock speed in relation to power consumption efficiency.
Out of the box, 2700X is optimized to it's best ability.
So single core apps, you'll see individual cores hitting clocks as high as 4350Mhz, say running PiMod. Well then you try to OC to manually get the same time, almost turns impossible for most people. Well the Cpu needs a lot of volts for the draw.
LLC is very useful to maintain a solid v-core for stability. It's a must for overclocking these chips.
Your Memory speeds are important just as much as the overclock. Faster is better.
Been working on personal settings for weeks now. It took some time to figure out, this processor only likes certain things. You can't force the voltage without the cooling. At a certain point (4500MHZ) with my chip, it seemed I lacked the cooling rather than the voltage. Didn't matter the core count either.
1st favorite overclock is running 8 cores SMT OFF and set multi to 43.50 and roll with Ext LLC and set voltage to + .3250v offset and let it fly. I used F@H for long term stability over a short IBT run. Good to go. Fast... Per core epeen is nice with SMT off believe it or not.
2nd favorite overclock is SMT on and 4200Mhz same voltage settings as above. tested the same as above.
3rd favorite setting is leave it stock. It uses less juice at the wall, does a nice solid 4ghz on a full load and does everything just fine. This setting I use when away for long periods of time.
4rth but not least is running quad core SMT off and 44.50x multi but closer to 1.6v, maybe a tad under.
So for some light benching, here's a sample picture of 4500Mhz on 4 cores and how it would look. Yes stock cooling.
++ additional comment::
I should mention that the offset voltage plays off the highest P-state of 1.212v, so when you see +3.0v suggested your at 1.5v depending on v-droop and LLC setting.
What does this "offset"+ vs - actually do different than a manual vcore with LLC enabled?
When I do stock auto, and do CB15, my cpu actually underclocks from 4025 to 3095 ish. Anyone else seen that? If i enable PBO i seem to get too high vcore at least in CPUz if I can trust those values. How do I get stock auto with PBO to boost to 4350Mhz? doesnt happen with Super PI tests for me ..
I get + 0.3250v offset = 1.525v with LLC on high it droops a little runs about 1.515v = Is what it takes to run Ryzen 2700X SMT enabled at or near it's turbo clocks of 4350Mhz. This voltage can be lower however with SMT turned off while the cores will ultimately use less energy in this fashion thus create less heat.
Under 1.45v will be an offset of positive + 0.2500v which would land you at 1.46v LLC set to extreme it should be as set in bios as it is with windows readouts with small fluctuations.
So with an + 0.250 offset, I can tell you that 4.1ghz will be stable, should be able to run that closer to 1.4v which would be +0.200 offset.
You may try to run 4.2ghz at 1.46v. Mines pretty stable about there. IBT passes, F@H all night no issues.
SMT off is a good thing. Most games aren't going to scale at 16 threads, so take advantage of the epeen. Same thing with most every day apps.
Your throttling. If it hits 85c that's what it'll do.
V-core offset is how you manually over or under volt the processor. (IE: + = over stock VID 1.212v and - = under 1.212v) by very small fractions.
LLC is what prevents v-droop. Most of the time, extreme works the best as far back as I can remember to socket AM2.
When using PBO you'll likely need to set an offset (either positive or negative) as well to keep your voltage where you want/need it. It's best to monitor your load voltage using HWINFO 64 it's free to use and gives a ton of info. The Ryzen CPUs will have occasional high voltage spikes but this is normal for the max boost so is the voltage droop under load. I find these CPUs run cooler if you work with the v-droop instead of overcompensating by setting a high LLC mode.
Maximum voltage which you run under load is up to you, AMD recommends 1.35V and up to 1.45V warning of possible deterioration of the CPU but this is over years of use. If you plan on upgrading in five or so years then I would be too concerned with running the CPU at 1.45V as long as you're keeping the temps in check.
I have a nice R5 2600 which runs 24/7 at 4.2 GHz with 1.35V (+0.200 offset with boost disabled) with LLC at 3 IIRC. Under load it droops to ~ 1.32V, like I said it's a "good" R5 2600
The VRM temps are fine, they have a long way before that's a problem.
I still think you should work with offsets and the performance boost overdrive. It gives the best of both worlds. Reset the board and reboot, then set memory and reboot. PBO works in stages at least my ASUS does start checking each level and adjust V_Core as needed either up or down. You may get 4.1-4.2 all core and still retaing the 4.35 boost bin for lighter loads
He's running a higher clock and RAM tuning helps a bit. One thi I read, you have the memory "overclocked" to 3000 with 1.2 V? That's likely too low, 1.35 V sounds a bit more likely for a proper voltage for RAM at that speed.
THE XFR2 being referred to is actually PBO performance boost overdrive. You should be able to find the settings in the Advanced section in BIOS look under AMD CBS heading it'll be in there may have a slightly different name but has different levels. It should allow you to set your all core boost a bit higher to 4.1 maybe 4.2 and will also keep the 2 core boost at 4.35. It's a very easy way to overclock. Leave the voltage on auto and use offset if needed to get the voltage where you need it.
When checking core speed what do you use. CPUz only reports from core 0 so if other cores boost higher you won't see it. You can right click on CPUz and it will show all cores in a pop up box.
For PBO is there a manual option?
Okay. So i'll try staying beneath 1,45 core voltage, and maybe more than this is ok for boosting. Do i trust vcore in cpuz or hwinfo? They are always different.No SOC VID won't change anything. I had read that the newer BIOS had gimped the PBO function which is a shame. You can still use PE with offsets. You just need to find the balance between voltage and speed.
Robert Hallock from AMD explained this perfectly.
The CPU is programmed to use these voltages automatically. We know it's safe, because we designed it that way. The CPU cannot and does not use voltages that are unsafe for the silicon.
The key thing that people forget in these cases is time and temperature. Running 1.4V or 1.5V here and there is not a big deal, because the CPU will eventually back down according to its pre-programmed model. Or if you have great cooling, that also offsets the thermal effect of voltage. In either case, you're seeing momentary blips of voltage that are offset by the hours per day your CPU is probably doing nothing at all--at a very low voltage.
The average vcore for Ryzen over time is around 1.25V (give or take).
