Upon Request, pictures of my rig.
Red = CPU with Asus bare heatsink
Blue = Fans (1x92, 1x120mm @ 6v using coolermaster aerogate 3. absolutely silent)
Green = RAM with heatspreaders. Cooled by 120mm.
Yellow = x800 with 70mm fan set to silent mode
Purple = Harddrives. No fans, just a little bit of airflow from 120mm.
Overall, the only thing that really making noise in my system are the harddrives (whine) and the PSU (slight humming noise). My wires are *slightly* cleaned up, mostly just out of the way of airflow. The thin black one to the bottom of the case is the temp sensor that used to be on my 9800XT but now has no purpose anymore. I run with the sidepanel on at all times now, it helps a good deal in blocking the HDD whine.
Because of the way the case is filled and placed in my room, theres a convection flow from the bottomfront to rear. Even without any casefans theres a steady flow of warm air coming out of the top rear hole and middle grilles. CPU temps are sub 50, RAM sub 45 and VGA sub 70 on full load. I'm loving it
