That voltage...
Yeah, definitely not going to be a daily overclock. It looks like 4.8 is my wall as it will easily do 4.7 stable on 1.421v.
That voltage...
My i3 6100 needs 1.7v for 5.2Ghz benchable.I was playing with i3 6320 yesterday and I needed similar voltage for 4.8-4.9GHz. Actually 1.5V for 4.9-4.95GHz but 4.8GHz was quite stable at about 1.45V. Hard to call it safe but if temps are low enough then it should live for a while
Posted that i3 result here already so won't upload it again.
They will do 4.7-4.8 on stock volts once you break that point the voltage demand increases dramatically.I got mine i5 6600k 3 days ago and it's freaking insane.. ive managed to reach 4.6ghz stable using stock voltage..chip roulette guyss
What does your CPU-Z show for voltage at 4.6GHz screen shot?I got mine i5 6600k 3 days ago and it's freaking insane.. ive managed to reach 4.6ghz stable using stock voltage..chip roulette guyss
That sounds about right. Don't let these guys give you **** I knew what you meant.Cpu voltage in cpuz is 1.175-1.21 and yes i would agree that my cpu needs a lot more voltage to get stable at higher than that.. at 4.8ghz it's stable only on 1.41volts with calibration on high
I need to get a DICE pot All I have right now is my modded Cryo-Z. Could you recommend a good place to get a DICE pot?I have only access to dry ice ... or maybe I could get LN2 if I really wanted but I have no dewar and it's way too expensive here. On dice it can make 5.6GHz for benchmarks. I have no idea how it looks like after delidding. On LN2 similar chips can make 6GHz+ but hard to say how mine will OC as voltage steps are different on each cpu. It may scale good on LN2 or will require much higher voltage. Matter of luck.
I wish to test it with water block directly on core but I have to prepare socket and check if contact will be good as core is really small. I just want to check if temps will be much better this way.
On the other hand socket A processors were working fine with even large coolers while cores of semprons were also small ( similar to this i3 ).
I'm wondering how well an F1 Gemini 2.0 would work with DICE. I have an airgas close but the cost of a dewar is what kills me.The classifieds all around?
He is in Poland, not sure he can help much retail wise.
What do you have for a motherboard?I have mine at 4.8 with the cashe at 46x. Voltage is 1.395 but gets up to 1.40 when stress testing.
