Ok so you re installed the Nvidia Gpu drivers and did a clean install? Nothing changed, it's still stuttering? The Hwmonitor in post #15 is that under load or Idle?Actually i do not have games downloading from steam. I have no idea why it is using so much memory.
Please, elaborate how this will help his problem at all...
I had major lagging (including cheap-USB-pendrive-like-speeds) until I resetted the SSD using that method.
(Halo CE also loaded maps slowly.)
That means the problem was in the OS or software, you can do a normal format/reinstall and achieve the same result.
